Cylinder 4 misfire
Discussion in '6th Generation Honda Civic (1996-2000)' started by JesseJames614, Jun 13, 2017.
  1. JesseJames614
    JesseJames614 New Member
    Jun 13, 2017
    15
    Columbus Ohio
    My 96 LX is sick. #4 cylinder isn't firing. I've checked injectors, changed the wires, button, cap, plugs and coil. Please help!!!
  2. boofoo
    boofoo Respected Registered VIP
    Oct 15, 2016
    2,245
    United States
    Compression test the cylinders.
  3. JesseJames614
    Jun 13, 2017
    15
    Columbus Ohio
    Wouldn't compression effect more than one or two cylinders?
    Sent from my LG-K550 using Tapatalk
  4. boofoo
    Oct 15, 2016
    2,245
    United States
    Your engine can lose compression in 0, 1, 2, 3 or 4 cylinders.
  5. JesseJames614
    Jun 13, 2017
    15
    Columbus Ohio
    I'm only asking because I don't know. How would this cause a misfire?
  6. boofoo
    Oct 15, 2016
    2,245
    United States
    A working cylinder absolutely requires compression to exert force on the piston.
    Get a cylinder compression tester.
  7. JesseJames614
    Jun 13, 2017
    15
    Columbus Ohio
    If it happens to be the cylinder, what is there that can be done? With a motor with close to 300xxx I can't see rebuilding it.
  8. boofoo
    Oct 15, 2016
    2,245
    United States
    Don't get ahead of yourself. Diagnose and then discuss options.
  9. JesseJames614
    Jun 13, 2017
    15
    Columbus Ohio
    Ok. I only see one more test that canbe done and that is compression.
  10. boofoo
    Oct 15, 2016
    2,245
    United States
    What test did you do on injector #4?
    Have you checked for bright spark at #4 plug?
    Are CEL codes thrown?
  11. JesseJames614
    Jun 13, 2017
    15
    Columbus Ohio
    I pulled the injector plugs to check for change in idle as well as plug wires. Checked the resistance in injector wires all are at 13.5. Its blowing a lot of white smoke from the tail pipe which I'm assuming is fuel that isn't being burnt. Number 4 plug was the worst with a little burnt oil when I changed them.
  12. boofoo
    Oct 15, 2016
    2,245
    United States
    Check for spark at the plug and for fuel spray from the injector. If both are fine, compression test the cylinders.
    CEL codes?
  13. JesseJames614
    Jun 13, 2017
    15
    Columbus Ohio
    Cel codes. Misfire on cylinder 4 and 2 and random misfire. I've checked for spark at the wires. All spark except for 4.
  14. boofoo
    Oct 15, 2016
    2,245
    United States
    So, do you think no spark at plug 4 is relevant?
    And you didn't think mention of misfire in cyl 2 and random misfire was also relevant?
  15. JesseJames614
    Jun 13, 2017
    15
    Columbus Ohio
    Misunderstanding. I assumed that cylinder misfire would cause it not to spark. And I checked #2 plug and it seemed to be firing fine. Didn't think it was important.
  16. JesseJames614
    Jun 13, 2017
    15
    Columbus Ohio
    No more suggestions?
  17. boofoo
    Oct 15, 2016
    2,245
    United States
    The new information should have been included in the first post. Is there any more potentially relevant information that you haven't shared?
    Can I assume that the engine runs?
  18. JesseJames614
    Jun 13, 2017
    15
    Columbus Ohio
    Yeah it runs.
  19. JesseJames614
    Jun 13, 2017
    15
    Columbus Ohio
    I drive it every day. My only ride got now. 50 miles each way to work.
  20. 98civlyfe
    98civlyfe New Member
    Jun 22, 2017
    19
    Oregon
    Cap and rotor?
Loading...
Share This Page
