D15b2 swap to D16y8 questions
91DXSedan
Hey everyone!
I've got a 91 Honda Civic dx sedan currently with a D15b2. I've got a D16y8 laying around that I'm thinking of starting to build and throw into my civic. What would I all need to do this swap? Thanks!!
xxBLOOD88SHOTxx
Surge Master
You're going to need the search button first and foremost. If you have any questions after that, you can come back and ask.
91EF01
Well I've been searching and searching a lot lately and still can't find everything I'm looking for.
For now I'm gunna be throwing on the Y8 head to my D15b2 block. Everything I have searched for is mostly about the Z6.
Right now I've got the obd0 to obd1 jumper harness, a chipped p28ecu, full y8 cylinder head with intake injectors,ect.. I'm currently running dpfi gunna go mpfi obviously.
Questions that I have are what head bolts should I use?
What timing belt to use? (I'm ordering a adjustable came gear also)
Will the y8 head gasket work?
And where would I splice in my harness to add my injector lines?
Thanks I appreciate anyone that can help me out!
joe etheridge
Im also building a mini me (d15b7 y8head) from everthing ive found use the y8 head studs y8 head gasket and timing belt and y8 dizzy
