Naughty33W
Hey guys, so I just picked up this 2000 HX in nice shape but running poorly. It really doesn't like to idle and it seems like there's no timing advance since she is REALLY difficult to get moving and bogs easily.
So, I decided to give her some much needed love and took care of: plugs, plug wires, dizzy cap/rotor, fuel filter, fresh gas, cleaned out EGR system, oil pan gasket (and oil change), checked all the fuses/connectors, vacuum lines, cleaned out the IAC, and several other misc bits. Throttle body looks good.
She runs better, especially if I bump the idle to 1000, but the overall problem persists.
Blip the throttle and she bogs then she is an absolute dog up till about 3000 where she smooths out a bit but still lacks any power.
She pulls a CEL after startup but only if I rev her. No code reader and Autozone is a bit far in her condition.
Can't confirm base timing because the idle is too bouncy but it is close enough that it should idle.
This basically leaves me thinking: dizzy itself or a specific sensor. Any ideas? TPS?
TPS output shouldnt matter that much for idle and the IAC shouldn't matter beyond idle :-/
Thanks
Thanks
