My question: why is my car loosing coolant?
Symtoms: Loss of all coolant in system, One hose will sometimes be warmer than the other hard to squeeze while warm, engine is hot after running more than normal, fans do not engage.
Observations/test: Fan does not turn on, heat/ AC works, thermostat opens at 195 degrees, does not leak under car, waterpump replaced 10k ago with OEM, radiator cap is oem and not broken, no coolant in my oil and even compression on all cylinders. temp gauge always reads normal and after a few days all of the coolant will be gone.
can anyone help me piece together what is going on here?
thank you!!
thank you!!
