Ecm alternator problems
Discussion in '6th Generation Honda Civic (1996-2000)' started by vep, Dec 3, 2017.
  1. vep
    vep Newbie 5+ Year Member
    Mar 6, 2008
    24
    Farmville NC
    Hey all been a while but I put a motor in my 96 lx d16y7 got it all running but iac valve.
    So a few weeks back got a cel for the iac which I knew was bad
    But the battery was not getting 14v running so I ordered a new alternator too.
    Installed them Iac works great but alternator the same also my code reader will not connect
    I think something went bad between the last time I read a code
    Checked fuses 15 for sure anyone have any ideas
  2. boofoo
    boofoo Respected Registered VIP
    Oct 15, 2016
    2,246
    United States
    Turn the key on ( Engine off). Then check whether the battery light/charging light in the cluster turns on and stays on.
  3. vep
    Mar 6, 2008
    24
    Farmville NC
    It does
  4. vep
    Mar 6, 2008
    24
    Farmville NC
    Cel light comes on too does the test then goes off about 3 seconds
  5. boofoo
    Oct 15, 2016
    2,246
    United States
    Does the warning light stay on with the engine running?
    What voltage do you read across the battery posts with the engine running?
  6. vep
    Mar 6, 2008
    24
    Farmville NC
    Warning light of get about 12.4v
  7. vep
    Mar 6, 2008
    24
    Farmville NC
    The only thing I did before the problem occurred was change the t-stat I think
  8. boofoo
    Oct 15, 2016
    2,246
    United States
    The charging warning light should turn on and stay on with the engine running when the voltage is only 12.5V.
    Did you forget to connect the large alternator cable to the alternator?
  9. vep
    Mar 6, 2008
    24
    Farmville NC
    Cables are connected gonna start it and see what lights are on now brb
  10. vep
    Mar 6, 2008
    24
    Farmville NC
    Ignition oil and battery lights.
    Engine running no lights.
    I am hearing clicking noises from the shifter in park too
  11. boofoo
    Oct 15, 2016
    2,246
    United States
    Make sure the alternator cable is also a securely attached at the hood fuse box.
    Is the G2 ground wire also attached to the chassis?
  12. vep
    Mar 6, 2008
    24
    Farmville NC
    I cleaned the g2 ground and wiggled the ground at the stat since that was the last place I work on and got 14v and my obd2 reader back
  13. vep
    Mar 6, 2008
    24
    Farmville NC
    Thanks for the help boofoo I owe ya beer
  14. boofoo
    Oct 15, 2016
    2,246
    United States
    Nice work!
Loading...
Share This Page
