ECU resets every time car is shut off
Friend just bought a 98 EX, bone stock minus a radio. He can't pass inspection because the catalytic system always says not ready.
Found out power to the ECU is being lost every time the car is shut off. Replaced ECU to verify, same results.
Any ideas? Never even heard of this before... lol
cgpEJ6
noob
Yeah that's bizarre, how does the ground on the battery look?
R3dline
thats pretty crazy, i think thats a first for me lol
Blown 7.5A hood Back Up fuse
This is what I was thinking... my friend brought the car to the guy who sold it to him since it's under warranty. He's getting it fixed for free regardless; I just thought it was a really strange issue.
We'll see.. once I find out what the issue was for sure I'll update...
got traction
i rock the sohc
how does that affect anything? ECUs get swapped all the time and no issues.
got traction
i rock the sohc
"power is lost to ecu everytime car is shut off" -- well isnt power lost to ecu when it is unplugged from harness? ECU's are swapped all the time and there is no issues like OP stated.
If this still does not make sense then im sorry. Pretty hammered right now
TigBitties
Frame Bangin
i think the problem is for inspection. Atleast in PA, if you swap a ecu or clear a check engine light, you have to drive so many miles for something to set up, idk what it is, but its involved with the emissions insepctions.
example would be if your running a obd2 car off an obd1 ecu, you would have to swap it and drive about 50 or so miles or you will fail
Correct. The Back Up fuse powers the circuit that allows the ECU to store learned information. If this circuit does not get power, then the ECU cannot store learned information and will indicate a "not ready" status for emissions testing.
Yep. He replaced the fuse though, still no dice
Click the Fuses link in my signature. Do both top test tabs of the Back Up fuse have battery voltage to body ground? If so, next test whether ECU terminal C10 has battery voltage to body ground.
found out it was a bad wire somewhere causing the issue... not sure which one though.
it's all fixed now, thanks fo the help :thumbs up
obracer12
^ then it wouldn't start at all...
This is an odd one.. The back-up fuse was a thought, but if that's not it, I would have to say to check the wires at connector A pins 4&5, 23&24 OR Connector E pins 3&4, and trace them back for breaks/metal contact... other then that I'm at a loss...
IlDuce
Ok i have a question. I see that there is an issue pointing to Blown 7.5 fuse.. Will having a blown fuse hinder performance? the numb nut who wired the radio in the car wired the main power to the back up line.. ex: Radio resets every time i turn the car off.. If i put in the back up fuse (7.5) the radio doesnt shut off. my ECU was chipped, i dont know with what.. need to check on that.
Is it causing performance issues by not having the backup fuse in?
