[CLIFFS AT BOTTOM]
I think I'm about to replace the starter on my 99 Si. I tested my battery and im getting ~12.5 V, but my car wont start. I turn the key to start and hear nothing except a very, very low hum, sometimes. I am able to push start it, so I assume the starter went bad?
I'm not that great with mechanical stuff (I can change my oil, and do some of the basic things). With that being said, is replacing the starter something I could DIY? I looked in the engine bay and the starter (the cylindrical thing?) looked like it was pretty far down there and hard to reach.
Also, is there anything easier/cheaper that I could check first before replacing the starter? My negative battery terminal is corroded and I eventually need to replace it, but I can run all my electric stuff. Does it take a lot more power to start a car than it does to run amps/headlights? If so, perhaps theres too much resistance on that wire?
[cliffnotes]
1. battery is running 12.5v + can push start car = bad starter?
2. Can I (with limited mechanical skills) replace my starter without too much hassle?
3. Should I check anything else before replacing my starter?
[/cliffnotes]
[cliffnotes]
[/cliffnotes]
