em2 sitting over a year with slung rod cost to make run again
googlemechanic97ek
so a buddy of mine has a em2 with a slung rod rest of the car is clean even has a fake si look to it badges and grille has coil over intake and a full 3in exhaust and headers he selling it to me for 500$ but i have to replace a engine and probably brake and gas lines and the whole fuel system anybody have a general idea of what the cost to bring it back from the dead i figure ill bee 2 Gs deep before i hear it even crank 12355195_10153259028167215_1180192437_n (1).jpg received_10153259028307215.jpeg 12355195_10153259028167215_1180192437_n (1).jpg received_10153259028307215.jpeg 12355195_10153259028167215_1180192437_n (1).jpg received_10153259028307215.jpeg
googlemechanic97ek
didnt mean to double upload the pic sorry guys im a absolute novice i know take it easy , fixing this car is how i plan on gaining my knowledge and experience
dancam
Member
Ive replaced 3 motors in 7th gen civics, they seem to like to throw main or big end bearings. $500 for a used engine already pulled with warranty from a wrecker, $150ish clutch kit off ebay, $150ish timing belt and water pump off ebay, coolant, belts, mtf, oil change... Thats like $900. Most civics still have fuel and brake lines in pristine shape so go to a pick it yourself wrecker and maybe $100 youll have it. Why do you need to replace the whole fuel system? And whats up with the brake lines? Hows the tire tread? How are the brakes and rotors? How many km on the body? Anything else wrong? Head gasket is still fine? They are common to go. Looks to me like $1500. Figure out what your time is worth to you and check kijiji and craigslist to see what similar ones are goin for.
googlemechanic97ek
i havent seen the car since it was running i just figure will ethanol gas the fuel system would get eaten up i have'nt checked anything else on is has some camber wear but i can live with that im just trying to figure my budget for the whole build id like to do a b16 swap if i cant find the money but thanks i didnt even thing to check all that other stuff
mc360
boosted hx
Much easier to install a k series than it is to go backwards and install a b series
HeX
Authoritah, respected.
Simply click the edit option in that post and delete the repeated attachments, then preview or just save.
HeX
.., Why do you need to replace the whole fuel system? And whats up with the brake lines?
Exactly my question.
i havent seen the car since it was running i just figure will ethanol gas the fuel system would get eaten up i have'nt checked anything else on it.... i didnt even thing to check all that other stuff
Never just guess or assume anything when it comes to repairs. It leaves you open for avoidable mistakes that could lead to more costly repairs. Make sure to thoroughly check the car, even if you trust your friend. You should be well aware of the project your buying.
