We are having a sale on Exedy Racing Clutch Kits and Flywheels.
Exedy Racing Stage 1 Organic Clutch Kit
Exedy Racing Stage 1 Organic Clutch Kit only use premium friction materials that are resistant to slippage and burst. Increased clamp loads give the necessary capacity to handle modified engines. This is the preferred clutch for street and light horsepower track use. Exedy Racing Stage 1 Organic Clutch Kit driveability is similar to the stock clutch. Pedal efforts will be slightly higher because of the higher clamp loads. All of our clutch discs have spring center dampers to reduce drivetrain shock.
Shop at TunerSports
http://www.tunersports.com/exedy-racing-stage-1-organic-clutch-kit_mp271.html
OR
Shop in the CC Store
http://www.clubcivic.com/store//exedy-racing-stage-1-organic-clutch-kit_mp271.html
Exedy Racing Stage 2 Cerametallic Clutch Kit
EXEDY cerametallic clutches are designed to handle the abuse of high powered modified engines. Our cerametallic friction material can handle much more slippage than stock type disc assemblies without slipping and fading. All cerametallic discs feature spring center dampers to reduce impact and shock loads.
We offer two types of cerametallic discs:
Normal Thickness (Thick)
Reduced Thickness (Thin)
Normal thickness discs have greater heat capacity and therefore better durability in demanding applications such as all wheel drive.
Reduced thickness discs offer greatly reduced inertia to improve shift efforts and improve synchro durability. These discs are approximately 1/2 the thickness of a stock disc and are recommended for track use only.
Shop at TunerSports
http://www.tunersports.com/exedy-racing-stage-2-cerametallic-clutch-kit_mp272.html
OR
http://www.clubcivic.com/store//exedy-racing-stage-2-cerametallic-clutch-kit_mp272.html
Exedy Lightweight Racing Flywheel
Exedy Lightweight Racing Flywheel are made from solid one piece billet chromoly steel forgings. They are specifically designed to reduce weight and inertia for better engine response.
Most incorporate special design features to enhance air flow to improve the cooling of the clutch. The ring gear teeth are milled onto the flywheel unlike an aluminum flywheel where the ring gear is pressed onto the flywheel and have the possibility of separating from the flywheel.
Shop at TunerSports
http://www.tunersports.com/exedy-lightweight-racing-flywheel_mp273.html
OR
http://www.clubcivic.com/store//exedy-lightweight-racing-flywheel_mp273.html
You can also use the coupon code in my signature for extra savings.
Shop at TunerSports
OR
Shop at TunerSports
OR
Shop at TunerSports
OR
