tCtCtC
FS: OEM 98 / VTi Rear Lip, Duralast Battery, OEM Parts, + Much More
I got into an accident and I'm parting out my '98 HX. I'm starting off with all of the aftermarket parts first, but I'll have a full interior and other stuff up for sale once I have the time to take it apart. All prices are OBO, don't be afraid to send me an offer. I'd like to keep everything in SoCal for now, I'm in the 818 area. For the fastest response email me at suchacleantc@gmail.com.
SZ (eBay) Window Visors (96-00 Coupe / Hatch) - $15
They're the stick on type. The front of them goes under the mirror for extra support, and the rest is held on my double sided tape (you'll need to replace that, about $10 for a long roll from autozone). No scratches on them. Only fitment issue was that the plastic doesn't extend to the end of the door, it cuts off about 1/2" from the end.
96-98 Mugen Style Front Lip (Urethane) - $15
*The wrinkling is just from it being shipped. Let it sit out in the sun for awhile or just a heat gun and it'll return back to normal*
Only mounted a couple times, there's some light scrape marks on the bottom.
2.5" RandomTech High Flow Car - $40
Used for about 2k miles at most, I would cut off all of the piping on it cause whoever welded it on didn't do a clean job. The cat still works perfectly fine.
2.5" BBP N1 Style Muffler w/ Silencer - $20
There's probably only 200 miles on it. I replaced it for the OBX twin loop, this one comes with a silencer and brackets also.
Air Filter - $10
Clean, it came with the car but i decided to use a different filter.
Lower Dash Panel w/ outlet - $25
OEM 96-98 Cupholder - $25
OEM Shift boot w/ console (top plastic piece on shift boot needs to be glued) - $25
OEM 96-98 Glovebox (Type K) - $25
OEM 96-98 Climate Control w/ Bezel - SOLD
OEM 96-98 Lower Driver Side Dash Cover - $30
Esuse Fog Light Wiring Harness - $10
OEM 96-00 Fuse Cover - $10
The metal clip is missing.
OEM 96-00 Steering Column Covers - $20
A couple of the clips are broken.
OEM 96-00 Gauge Cluster Surround - $20
The clip on the right side is broken.
All pictures can be found here: http://s948.photobucket.com/albums/ad323/tCtCtC/For Sale/
Again, all prices are OBO. Just PM / Email me! I'll take the price down a bit if you buy multiple items.
Air Filter - $10
