My understanding is that is not the same engine. I already purchased the valve, so there is definitely a valve.I went to clean mine on an 02 non hybrid. Popped the cover off and there was no valve. Nothing really to get dirty or plugged up either. Its just always open. Is the hybrid also a D17 or not?
I have a hybrid.for the non hybrid engine there are two valves one on the valve cover and one near the oil filter at the bottom of the engine im guessing you mean the one on the valve cover. its located on the back of the valve cover with a rubber hose leading to the air intake. side note the 01-05 civics have metal PCV's and don't require replacements you just unscrew them and clean it with carb cleaner. the last generation had plastic pcv valve which required them to be replaced.
