Last time is rained, water got into my spare-tire compartment. I have a pool of rain water in my trunk. I have $ 400 subwoofers and a $250 amp sitting about 6 inches from the water. I need this out, or I'm screwed. How can I get rid of the leak?
take all that s**t outa your trunk, get a buddy, and hose pipe. you get in the trunk with a flashlight, let your buddy hose down the trunk of your car, and see where its comming from, then we will go from there
same s**t happend in my 95 ex honestly i drilled some holes and dident leave anyhting in the truck that couldent get wet...but it wouldent work in your case casue of the subs
seen this thread several times before...
anyway. hopefully yours isn't as expensive to fix as mine was, being that mine was in a bad rear-end accident that was fixed poorly & not known about by me when i bought it.
what im trying to figure out is why only the spare tire compartment is wet. its got to be coming from underneath because the sub box and other stuff in my trunk aren't wet.
I have the same problem. I have my amp, nd 2 12's. They both are very dry while an olympic size swimming pool forms just below it. my cars gutted out, nd i still cnt rlly track down where exactly its coming from.
Dude i had the same problem. I found out where mine is coming from just check it out. On the drivers side under your taillight is a piece of body thats there the water gets into now if you take your rear bumper off there will be a plastic piece on the side w/ like a rubber flap in it thats most likely where your water is coming from into your car. Sorry if im hard to understand lol
