you dont need to rotate the engine...
the camshaft is sloted at the end and is not center slotted.. and the distributor has a tab...which will match the slot...
there is no possible way to f**k it up when you put it back on. NEVER force it together... it will go back together as easy as it came off. if you find yourself having to force it... then it isnt lined up. take it off and spin the distributor until it matches.
dont worry about that note there on the service manual... its unnecessary.
