Hid won't turn on
94integra-ls
i have a 92 hatch and my drivers hid,or ballast is making a buzzing sound when I turn on my headlight.is that a bulb out or my ballast bad?
lethal6
Your Mom's Moderator
You are going to be the one that has to figure this out. We can't help you from here.
Start by swapping a known good bulb. If it works, the bulb is the problem, if it doesn't...swap in a good ballast. If they both don't work, you have a grounding or wiring issue.
Please tell me these aren't dropped into stock housings and are in proper retrofitted projector housings.
xxBLOOD88SHOTxx
Surge Master
Unless he bought a retrofitted car, someone who can't figure this out probably can't do a retrofit either.
If the ballast is buzzing you have power to it
94integra-ls
Yes they are in projectors
