Honda Newb with timing and speedometer issues
Discussion in '6th Generation Honda Civic (1996-2000)' started by mrbigA47, Sep 24, 2017.
  1. boofoo
    boofoo Respected Registered VIP
    Oct 15, 2016
    2,223
    United States
    The initial focus should be on a vacuum hose that you forgot to connect. If that gives no joy, consider replacing the IM and TB gaskets. Be sure to torque the nuts and bolts to spec with a torque wrench.
  2. mrbigA47
    mrbigA47 New Member
    Sep 24, 2017
    29
    California
    The throttle body gasket was the culprit. New one did not cover the same area as the old one. The car is running well again; HOWEVER, the idle still reads high (1100). I adjusted the idle screw on the TB to no avail. My gauge cluster came out of an LX Civic (98); I wanted a tach. Speedometer is also off (starts at 20). Could it be the gauges just need to be calibrated? The car sounds fine; unfortunately I am not versed enough on Hondas to attempt to tune by ear.
  3. boofoo
    Oct 15, 2016
    2,223
    United States
    The proper idle adjust procedure can be found in the service manual. You also need an external tach or code reader that reads engine rpm because the cluster tach is highly inaccurate at low rpm.
    Also check whether the throttle cable is adjusted a bit too tightly.
  4. mrbigA47
    mrbigA47 New Member
    Sep 24, 2017
    29
    California
    Ok. Can the gauges be calibrated or should I hunt for another cluster, preferably the original DX one, from the salvage yard? There is a 2nd outlet on the rear of the LX cluster that my DX wire harness has nothing for.
  5. boofoo
    Oct 15, 2016
    2,223
    United States
    Maybe I missed something. What makes you think the tach requires calibration?
  6. mrbigA47
    mrbigA47 New Member
    Sep 24, 2017
    29
    California
    I was speaking more for the speedometer, but they both can from the same vehicle and the old speedometer worked fine.
  7. boofoo
    Oct 15, 2016
    2,223
    United States
    All six generation civic speedometers read approximately 3 mph lower than reality. Is that important to you?
  8. mrbigA47
    mrbigA47 New Member
    Sep 24, 2017
    29
    California
    That's good to know. My speedometer starts at zero when at 20 mph and will not go below that until the car is off. The fact my old one did not do that is what generates this question. Wish I had NOT thrown it away.
  9. boofoo
    Oct 15, 2016
    2,223
    United States
    The speedometer may be bad.
    Is code 17 thrown?
  10. mrbigA47
    mrbigA47 New Member
    Sep 24, 2017
    29
    California
    No CELs.
  11. mrbigA47
    mrbigA47 New Member
    Sep 24, 2017
    29
    California
    Newb is a fitting term for me. It turns out the high idle was caused by me setting timing from the wrong mark. Timing is advanced. Good news is there are no vacuum leaks.
  12. mrbigA47
    mrbigA47 New Member
    Sep 24, 2017
    29
    California
    I have finally corrected my idle issue. I had to adjust the throttle "bump stop" screw in order to get it right. Just have to verify manual timing again and its off to the next facet of this project. Thanks for your assistance and by chance would you have a diagram of a Civic's rear door? Mine does not open from the out or inside.
Loading...
Share This Page
