How many Quarts in 1.6L?
kwtorbe
I just got a '97 Civic Hx with a 200,000 1.6L. I changed the oil and put 5 quarts in and it doesn't even read anything on the dipstick (I was on level ground and had started the motor and everything). HOW many quarts does a 1.6L engine hold? I suspect I have the wrong dipstick or I simply need another quart......
wmertz
~multi-colored beast~
i believe they hold 4.0 quarts, check your dipstick i would suggest. 5 is a little to many.
Eran
It's on ass-backwards.
They hold a little under 4 quarts. With 4, you should be fine.
05
Show Me Them Titties
its 3.8 or someshit, 5 is definitely too much
MilanoRed_EJ8
Yeah, its supposed to hold 3.75 quarts, depending on how much oil your engine burns, if any.
To be safe I would just drop 4 quarts of Mobil1 10w30 in it, 5 quarts is not "excessive", but you should put 4 quarts to be on the safe side.
In any case, just let it run for a little while once you change the oil, you won't find oil on the dipstick as soon as you change it.
Eran
I wouldn't use 10w30 or synthetic oil. Honda reccomends 5w20. I use Honda 5w20 in mine. It's made by Mobil ... but it's not synthetic like Mobil 1. There's absolutely no reason to run that weighty of an oil or to run synthetic in a stock to mildly-modded Honda motor.
1337 | RCE
teh broke enthusiast
i've always put 3.5 in. too little? I use 5w30.
kwtorbe
I did let the motor run awhile after I changed it. My guess is I have the wrong dipstick from the backasswards guy I bought the car from. Thanks all---now it looks like I need a new dipstick and to go drain a quart--fun times
DAF
Zinc Member
Its roughly 4 quarts. I'd you pour the oil in and then check your dip stick right after pouring it in? Your suppose to wait a little bit to let it all get to the oil pan, then check. That's also one of the many reasons why you don't check your oil right after or while your car is runing.
And does it run better on 5w20? I've been using 10w40 (b/c its summer).
got traction
i rock the sohc
its exactly 3.8 quarts. and i run 5w30, but its royal purple
bcivichb
Driving South
the car has to be cold when you check the oil. so its all in the pan, otherwise its in the engine and it wont read on the dipstick
Eran
5w20 Honda motor oil :thumbs up
I always run it, and my car runs great. I actually use all honda fluids .... but I'm anal like that :lol:
celtic11
Yours may be different due to the year or something but Honda recommends 5w30 for my car...
anyways, why does it take like 10 people to repeat the same answer over and over?
Eran
Actually, a TSB put out about a year ago lists yours as taking 5w20.
RKSskier
Um doesnt it say 5w30 and 3.8 in the manual.....
JiuJitsu_greg
Honda does reccomend 5W20. Castor oil is what the dealer I used to work at used. Except for the hybrids and though ran a 0 grade oil by honda. . . . .
http://www.ahm-ownerlink.com/Maintenance/maint_prev_maint.asp#oil
you will have to sign up for owner link to view link
PhntmSk8r
H23VTEC
Alot of this depends on altitudes/temperatures of which your vehicle is driven.
We (my parents, then me) had an old 88 honda accord lxi, a20a4. My dad had used 4 quarts of Castrol 10w30 in it since the FIRST oil change he did after purchase in 87. It now has 258k miles on it, and its still running strong. Located in colorado ive heard some not so good things about overly thin oil, but maybe thats just me? *shrug*
kwtorbe
I put in about 3.8 quarts of 5W 30 and an additive and then recalibrated my dipstick to be full at that point.
For some mechanical tech crap about what is better read the following knowing that oil choice is all about balancing engine protection for performance---lighter oils, while not as protective due to lower viscousity, provide more horsepower, torque, and efficiency (The heavier the oil the harder the engine has to work to overcome the parasitic effects). However, the heavy oils should provide better protection to engine components. I normally use 10W30 in the summer because more heat causes the oil to be less viscous and 5W30 in the winter, but I used an additive (Restore) this time. I have seen in Carcraft magazine where an additional 20hp can be found by running less and thinner oils (granted these are 550hp big blocks). Thanks for the speedy help to remedy my oil problem
