You definitely have to mention that you got turbo in your first post man..haha...that also has a huge factor in it.
Lol I didn't mention it since we were in the Forced Induction section but yeah it's there.
The tune is on a burned chip using highway pulls on a wideband hooked to a laptop and processed into chrome pro software. I'm fairly secure with the tune although I'm wondering if we leaned it a little too much in the last tune since my coolant temps are no longer as steady. I now get over 1/2 of the gauge if I hold the car at 75mph+ for 20 minute or more intervals. I can easily get the temp back to normal by running the heat, not on 'hot' and not on 4. Sometimes just having the slider to the red side is enough to keep it cool. I do have coolant lines running to the turbo - but I don't have a flowchart for the coolant passages so it is possible I don't have them running in the most efficient manner - not that it would make a huge difference, but it will when I start to run an auxillary electric water pump. I tapped one of the lines going to the TB area.
I have a 28" front mount, 2.5" pipes, 510cc injectors, 8psi - 9psi max, ramhorn manifold. Full boost at 3400.
How can I tell if my smokey exhaust is from turbo oil seals or from valve seals or rings? I notice it is kinda constantly lightly smoking. Only easy to see at night when there's a car behind me. Nothing to see at idle. Gets worse under boost, but also is black due to added fuel. Stops during coast, but then blows a puff when I touch the throttle again.
