anfrey
OG スバリスト
i do not take credit for this
________________
adjust clutch travel
for hydraulic clutch on my d16 tranny. if you go into the driver side door and, go to the clutch pedal, there should be a gold plate with a rod that is attatched to it and travels through the firewall.
behind the plate is a 12 mm nut on the rod. if you loosen that it will allow you to ajdust the clutch
after you get it loose, press in the clutch with your hand and rotate the rod so that the thread comes toward you/the rear of the car. this also adjusts the travel and pickup of the clutch - if you want your travel to be short and pickup quick, turn the rod about 5 times (it's pretty sensitive, a few turns should be enough)
________________
