How To: Install Skunk2 Shifter w/ Shift Bushings
Discussion in 'Engine Tech / Drivetrain DIY How-To's' started by stolibears, Feb 12, 2007.
  1. stolibears
    stolibears Use your dipstick Jimmy!! Registered VIP 5+ Year Member 10+ Year Member
    Jan 2, 2004
    1,040
    VA
    cause it is attached around the old shift knob...duh! If I were keeping the old shift knob I wouldn't have to. The new Knob doesn't have anywhere for the old zip tie to secure against, thus why I used the 4 washers and a new zip tie.
  2. Matt.
    Matt. Banned Registered VIP Registered OG 5+ Year Member 10+ Year Member
    Jun 3, 2005
    9,066
    Pa
    I have a 6th gen as well, and my shift knob wasn't attached to the boot. I simply unscrewed the knob and dropped the shifter. Did you try to do so?
  3. Matt.
    Jun 3, 2005
    9,066
    Pa
    Oh I see the difference. I guess si and normal civic are different.
  4. stolibears
    Jan 2, 2004
    1,040
    VA
    yeah, there is a clip attached to the bottom of the si shifter knob that the zip tie secures against. I guess other civics don't have that?
  5. KyoCivic98
    KyoCivic98 New Member 5+ Year Member
    Mar 3, 2007
    162
    AL
    so how exactly would this be different with a 96-98?
    all the write ups i have seen are for the SI's
    are there any different bushings i would need?
  6. stolibears
    Jan 2, 2004
    1,040
    VA
    yeah, the ones for the 96-98 are a 3 piece set where as the ones for the Si are a 2 piece set. I'll look up the part number for you later if you want.
  7. CSB
    CSB New Member Registered VIP 5+ Year Member 10+ Year Member
    Oct 26, 2003
    542
    Peru
    This is a great write up.
    Ive just got my new blox knob today and im changing my old momo knob.
    I was just wondering why those the knob come with a nut, cause the knob itself is threaded and fits perfecly in the short shifter, but from what i saw its only for securing the shift boot, or is there anorther reason to be used?
  8. stolibears
    Jan 2, 2004
    1,040
    VA
    not sure, I know for mine, even though the knob is threaded if you installed it with out the nut, the shift numbers on the top would be pointing the wrong way. So you have to use the nut on the bottom to secure it so the numbers are straight. Does you knob have the shift numbers on the top?
  9. Genuine Rolla
    Genuine Rolla Its PETEY PETE, y0! Registered VIP Registered OG 5+ Year Member 10+ Year Member
    Dec 1, 2004
    19,215
    Connecticut
    good write up..!
  10. Youngrasshopper
    Youngrasshopper New Member 5+ Year Member
    Aug 21, 2006
    24
    Wisconsin
    I did my short shifter yesturday but when I went to check out the throw of it, it felt so loose! I must have not added the oem washers and rubber washers. BTW I didn't have to take out my boot, I just popped my knob off. Saved me more time.
  11. zach246
    zach246 2 gsr hatches Registered VIP 5+ Year Member
    Oct 14, 2005
    1,144
    Boston, MA
    :thumbs up great job with this write up. i know it will come in handy in the future.
    someone sticky this
    is thsi suppose to act as a short shifter?
  12. stolibears
    Jan 2, 2004
    1,040
    VA
    did you also change out the bushings? when i did the research I found some people found that the short shifter actually felt looser then before when they went to an aftermarket shifter, without changing out the bushings too, especially in a "seasoned" car (older well used cars).
    when i did the mod, my shifter was VERY stiff at first, but now has loosened up a bit.
  13. stolibears
    Jan 2, 2004
    1,040
    VA
    thanks!
    depends on your meaning. this is a short shifter, in which the travel between gears is "shorter" but the literal sense, the length of the shifter is pretty much the same "height" as the stock. there is a write up in here in case you also want to shorten the length of the "height" of the shifter.
  14. drekoe
    drekoe New Member 5+ Year Member
    Feb 4, 2008
    55
    los angeles
    nice write up. did this today. got a short shifter like the one you installed (shape), but not a skunk2. also installed a new type r boot, and type r knob. feels great, quicker shifts.
  15. mmmkay
    mmmkay slammed status 5+ Year Member
    Feb 26, 2008
    96
    everywhere, CT
    when i did my shifter and all the shifters i've done i have someone sit in the car and shift it as im tightening the through bolt on the shifter- i noticed its a b***h to shift if you tighten it to much so i dont think there is a torque spec on that- its just personal preferance....
    great writeup tho!!!!
  16. honda98civic
    honda98civic New Member Registered VIP 5+ Year Member
    Dec 30, 2007
    513
    FLA
    so im not changing out the shifter bushings in my car so do i even have to take the shift linkage off of the tranny. im thinking all i would have to do is drop out the old shifter and run the new one up through the hole and just rebolt it??
  17. jasony816
    jasony816 New Member 5+ Year Member
    Oct 30, 2008
    15
    NYC
    I am having some problems with replacing the bushing on the extension rod end. Its so hard to put the new one on, any tips on putting that sucker in?
  18. stolibears
    Jan 2, 2004
    1,040
    VA
    [​IMG]
  19. Mugen23
    Mugen23 New Member 5+ Year Member
    Sep 3, 2008
    146
    Sacramento
    x2 nice
  20. jasony816
    Oct 30, 2008
    15
    NYC
    I tried that but I am having problems with the rounded lip part when i try to push it in. Do you just jam that sucker in or do you like squeeze the lip abit and squeeze at same time. Also does vasaline work?
Loading...
Share This Page
