How To: Oil Change for Newbies.
Discussion in 'Engine Tech / Drivetrain DIY How-To's' started by joe7987, Jun 5, 2005.
  1. joe7987
    joe7987 Moderator Staff Member Registered VIP Registered OG 5+ Year Member 10+ Year Member
    Oct 27, 2003
    14,362
    Orlando, FL
    How to change your oil
    The newbie's guide to chaging your oil
    The process is quite simple, even you can do it.
    Things you'll need:
    • oil change pan
    • 3.5 quarts of oil
    • oil filter
    • 17mm socket wrench
    • funnel
    • rags
    First step: Gather materials (pictured below)
    [​IMG]
    Second step: Jack your car up on both sides if possible (pictured below)
    [​IMG] [​IMG]
    Third step: Locate the oil drain plug underneath the car, plugged into the oil pan (pictured below)
    [​IMG]
    Fourth step: Move your oil change pan under the drain plug, grab your 17mm socket wrench and get that baby out of there... let the oil drain into the pan and try not to get any on your clothes... (pictured below)
    [​IMG]
    Fifth step: Get under the car and twist the old oil filter off with your hands. If you can't, they make a clamp that fits around the end and assists you in getting it off (pictured below)
    [​IMG]
    Sixth step: Reinsert the drain plug after all the dirty oil has been drained and replace the old oil filter with the new one. Open your oil cap and get the funnel in there. Pour 3.5 quarts of fresh 5W30 oil in that sucker (pictured below)
    [​IMG]
    [​IMG]
    Seventh step: Put the cap back on the valve cover, run your motor, turn it off and let the oil settle, then check your oil via dipstick and insert oil accordingly (pictured below)
    [​IMG]
    After all of this, take your car out for a spin and make sure everything is working properly.
    You're good to go 8)
  2. 97ej6mike
    97ej6mike New Member 5+ Year Member
    Nov 27, 2006
    4
    Lincroft
    DE DE DEE!
    lol
  3. 99SilverCX
    99SilverCX New Member Registered VIP 5+ Year Member 10+ Year Member
    Feb 15, 2005
    615
    Chicago
    FYI. Different motors use different amount of oil.
    I was told by a dumbass at Autozone that my B16 takes 3.5 Quarts, I did 3 oil changes before I found out out in a Hanes manual that B16A requires 4.2 Quarts. So basically I ran my engine 9k miles on .7 quarts short of oil.
  4. neoc03
    neoc03 I CRAVE CORNERS Registered VIP 5+ Year Member
    Oct 15, 2007
    1,229
    NC
    Nice valve cover paint job. Did you do that with a spray can or a gun. Either way looks really smooth.
  5. EgHatch93
    EgHatch93 EG Whore Registered VIP 5+ Year Member
    Mar 15, 2006
    1,358
    Tyler, Tx
    Ummm Penzoil is the WORST s**t evar :P haha. Castrol FTMFW... Good write up kinda pointless though =/.
  6. zach246
    zach246 2 gsr hatches Registered VIP 5+ Year Member
    Oct 14, 2005
    1,144
    Boston, MA
    good write up. gutta start somewhere
  7. daboyu978
    daboyu978 Banned
    Jul 6, 2005
    1,618
    USA
    thanks god for your write up i finally did my 87976456468468468 miles oil changes, thanks!
  8. Dough
    Dough New Member 5+ Year Member
    May 21, 2006
    152
    Canada
    Ep3po likes this.
  9. Raabe
    Raabe Hell yea I suck toes! Registered VIP Registered OG 5+ Year Member 10+ Year Member
    Jun 3, 2007
    5,503
    The Desert
    TIP: make sure to check that the OLD oil filter gasket isnt still attached to the block
    Ep3po likes this.
  10. Kaotic_Zeus
    Kaotic_Zeus Most hated man Registered VIP Registered OG 5+ Year Member
    Jul 4, 2005
    6,609
    Fresno, Cal
    this is fucking old man lol
    i thought joe had a d17?
    and any other oil filter but fram or penzoil filters honeywell is the same as those they're s**t, and penzoil is not that great but it works as long as you change it at the 3k interval. I would replace the drainplug gasket too, if you havent for a couple of changes. use your fingers and wipe some new/old on them to lubricate the new filter's gasket. check oil when the engines is cold
    and man am i bored..but whatever...
  11. msmattie1667
    msmattie1667 New Member 5+ Year Member
    Feb 27, 2009
    2
    Birmingham AL
  12. littlej988
    littlej988 New Member
    Jan 14, 2017
    1
    Chino Hills, CA
    step by step instructions...
Loading...
Share This Page
