CivicVP
I took the rear wheels off the USS Rustbucket because the rear brakes where whistling when the brakes are released. I think it's the typical metal rubbing on metal. So I'm going to clean the drum brakes and put some grease on the contact parts.
When I took the wheels off I found some severe? corrosion. The car is in a dryer environment now with no salted roads. The front wheel assembly is wet with white vinegar. It made little difference. I was able to scrape off a few layers of rust
What parts should I replace?
