New 2017 Honda Civic Type R Makes Global Debut at Geneva Motor Show
Discussion in 'Site News' started by Jay Jay, Mar 9, 2017.
  1. Jay Jay
    Jay Jay Administrator Staff Member Registered VIP Registered OG Premium 5+ Year Member 10+ Year Member
    Jan 1, 1970
    5,342
    Mar 7, 2017
    • First Type R-badged Honda available in the U.S. goes on sale late spring
    • Most powerful, quickest, fastest and most agile Civic ever
    • 2.0-liter i-VTEC® DI TURBO: 306 horsepower and 295 lb-ft. of torque
    • Major chassis and suspension upgrades for track-ready performance
    GENEVA – Honda today took the wraps off one of the most anticipated models in its history with the unveiling of the production 2017 Civic Type R at the Geneva Motor Show. The long-awaited Civic Type R, slated to go on sale in the U.S. in late spring with an MSRP in the mid-$30k range, is the first ever Type R-badged Honda to be sold on American soil. The Type R will feature a high performance 2.0-liter turbocharged powertrain, substantially upgraded body and chassis, and other track-ready, Nürburgring-tuned and tested performance components. The 2017 Civic Type R will make its U.S. debut at the New York International Auto Show on April 12, 2017.
    "The fastest, most powerful Honda ever sold in America, the Type R caps off the incredible success story of our 10th generation Civic lineup," said Jeff Conrad, senior vice president & general manager of the Honda Division, American Honda Motor Co., Inc. "We're happy to inform our U.S. enthusiasts that the long wait for the forbidden fruit of Honda Type R performance is nearly over!"
    The new Civic Type R, sharing the body style of the 5-door hatchback variant of the tenth-generation global Honda Civic platform, will be powered by a U.S.-built 2.0-liter DOHC, direct-injected and turbocharged i-VTEC in-line 4-cylinder engine with peak ratings of 306 horsepower at 6,500 rpm and 295 lb.-ft. of torque from 2,500 to 4,500 rpm. The engine will be mated exclusively to a short-throw 6-speed manual transmission with rev matching capability – employing automatic throttle blips for smoother shifts and power delivery. A new single-mass flywheel reduces clutch inertia by 25 percent versus the previous (European) Type R and a lower final gear ratio is employed to improve acceleration response.
    The Civic Type R chassis builds on the major upgrades undertaken for the 10th-generation Civic makeover with model-exclusive spring, damper and bushing settings, a new Dual-Axis front suspension setup with aluminum lower arms and steering knuckles for improved at-the-limit cornering and reduced torque steer; a new four-wheel Adaptive Suspension System with three-chamber dampers; a retuned and adaptive dual-pinion electric power steering system with variable gear ratio; and a helical limited-slip front differential. Mounted to the suspension are 20-inch aluminum alloy wheels shod with 245/30R 20 Continental ContiSportContact 6 performance tires. Decisive stopping power comes from Brembo 4-pot aluminum calipers squeezing 350mm (13.8-inch) cross-drilled rotors at the front. The rear braking system features solid 305mm (12-inch) rotors.
    The Type R's scalpel-sharp responses are further enhanced by a body more rigid than the substantially improved Civic Hatchback on which it's based – with a 38 percent increase in torsional rigidity and 45 percent gain in bending rigidity versus the previous Civic Type R – enhancing steering response and cornering stability while mitigating body vibration and cabin noise. The improvements are made possible by the application of structural adhesive throughout the body. Ultra-high strength steel is used for 14 percent of the body structure, and the Type R has an aluminum hood, contributing to a 16 kg (35 lb) reduction in body weight versus the previous Type R, and a 7 kg (15 lb) reduction versus the base 2017 Civic Hatchback.
    The 2017 Civic Type R is designed to reward the driver in all driving conditions, on the track and on the street, and features three driving modes: Comfort, Sport (default) and +R. The driver selectable modes adjust steering and throttle response, transmission rev-matching, Vehicle Stability Assist (VSA) and the Adaptive Damper System. Utilizing new, three-chamber dampers, individual stroke sensors and three vehicle-G sensors, the new damper system offers a wider range of variability for ride comfort and dynamic handling response.
    The 2017 Civic Type R will launch this spring in a single, premium-contented Touring trim. A 7-inch Display Audio touchscreen interface with embedded Honda Navigation system has both Apple CarPlay™ and Android Auto™ compatibility; and should the driver ever tire of hearing the Type R growl, a 540-watt, 12-speaker audio system with SiriusXM 2.0, HD Radio and Pandora compatibility is also provided as standard.
    Additional interior Type R features include heavily bolstered sports seats, leather-wrapped steering wheel and shift boot, aluminum shift knob, aluminum sport pedals, red Type R driver's meter and serialized Type R plate on the center console.
    The Civic Type R will be manufactured by Honda of the U.K. Manufacturing in Swindon, England, with its 2.0-liter turbocharged engine made by Honda of America Mfg. at its Anna, Ohio engine plant using domestic and globally sourced parts. Pricing specifics and additional details on the 2017 Civic Type R will be provided closer to launch.
    Specifications and Features Overview
    Powertrain
    Engine Type
    L-4 2.0L DOHC i-VTEC turbocharged engine with dual valve timing control
    Horsepower
    306 horsepower @ 6,500 rpm
    Torque
    295 lb-ft of torque @ 2,500-4,500 rpm
    Transmission
    Chassis
    Drivetrain
    Front wheel drive with limited slip differential
    Steering
    Dual pinion electric power steering with variable ratio and active steering
    Suspension
    Dual axis front strut suspension and independent multilink rear suspension with adaptive damper system
    Brakes
    Front Brembo aluminum four piston calipers with drilled 350mm (13.8-inch) rotor brakes. Rear brakes feature solid 305mm (12-inch) rotors
    Wheels
    Tires
    Driving Modes
    Three-mode driving dynamics control with Comfort, Sport (default) and “+R” modes adjust dampers, steering, throttle response, transmission (rev matching), VSA (vehicle stability assist) and traction control systems
    Body
    Increased body stiffness over current Civic Hatchback and previous generation Type R
    Exterior
    LED headlights, fog lights, brake lights and turn signals
    Interior
    High-bolstered sport seats with red/black suede-effect fabric
    Leather wrapped steering wheel
    Leather wrapped shift knob
    Sport/racing pedals
    Illuminated visors
    Features
    Display Audio with Navi
    Dual Auto HVAC
    XM and HD Radio
    12 speaker 540-watt premium audio system
    Android Auto™ and Apple CarPlay™
    01___2017_Civic_Type_R__European_Version_.jpg 02___2017_Civic_Type_R__European_Version_.jpg 14___2017_Civic_Type_R.jpg 13___2017_Civic_Type_R.jpg 12___2017_Civic_Type_R.jpg 10___2017_Civic_Type_R.jpg 11___2017_Civic_Type_R.jpg 09___2017_Civic_Type_R__European_Version_.jpg 08___2017_Civic_Type_R__European_Version_.jpg 07___2017_Civic_Type_R__European_Version_.jpg 06___2017_Civic_Type_R__European_Version_.jpg 05___2017_Civic_Type_R__European_Version_.jpg 04___2017_Civic_Type_R__European_Version_.jpg 03___2017_Civic_Type_R__European_Version_.jpg
    XpL0d3r likes this.
  2. XpL0d3r
    XpL0d3r What Civic? Staff Member Registered VIP Registered OG 5+ Year Member 10+ Year Member
    Mar 8, 2007
    8,894
    Rochester NY
    Definitely at the top of my next car list. Not looking for a new car for another 2 years or so (once all my school loans are paid off).
    I WANT IT.
    ImportFan1 and Jay Jay like this.
  3. MotorMo
    MotorMo Respected
    Mar 31, 2016
    167
    Sonoma, CA
    Interesting that they went direct injection. It seems Honda is having some issues with these yes? So many "Earth Dreams" engines are setting misfires codes, shaking at idle, and other problems that they don't yet have a cure for yet.
    Love the fact that with the 'fly by wire' throttle body style, they programed the ECU to 'burp' the throttle for you when shifting- no need to heal-toe any more haha.
    Max HP at 6500 RPM seems low to me...Cant wait to see what the community is going to build with them.
    I would love to test drive one......
  4. J32Civic
    J32Civic New Member
    May 3, 2017
    2
    Berks, UK
    Shame you guys get the 306hp variant stateside. In Europe it's closer to 320. Can't think why that is though - anybody know why?
  5. XpL0d3r
    Mar 8, 2007
    8,894
    Rochester NY
    Probably emissions related
Loading...
Share This Page
