I have an NOS system that cam with 50, 60, &70 jets. Would a stock bottom end hold up to more than 50? Only gonna be used for dyno and track runs, so it wont be every day use.
Thanks for the advice. I also found a nitrous controller that is suppsoed to allow me to control the flow of nitrous based on rpm or allow me to select what gear the nitrous is activated in. I will definately look into a hondata or uberdata to do it correctly.jason_guy_yeah said:What ever you do, don't use the afc hack for your nos. If you're going 70 shot dry, look into a stage kit and some sort of chipping kit. (hondata, uberdata, ...well, ask your tunner what they're familiar with). You don't want 70 shot all at once and leaned out.
That was going to be my next question because the instrutions say not to use with devices that advance or retard the timing. I have heard to retard the timing but i wasnt sure.oc_civic said:"retard the timing like crazy"
someone posted this and then deleted it, but they are right.. retarding timing a little bit will actually help protect the motor..
