no crank, no start: '09 Civic
family mechanic
hello all. new member looking for help with my daughters 2009 civic. the issue started as an intermttent no crank, now permanent. had new starter installed, did not solve. i have power at the yellow wire (using a test light) at the upper portion of the inside fuse box when key is in start position. the two wires to the left are hot when key is in run position and lose power when key is in start position. i am guessing this cuts out some circuits while the starter is engaged. also guessing this indicates a functioning ignition switch. i am not sure what to check from here. a wiring diagram for the starting circuit would be great.
thanks in advance for any replies.
andy, the family mechanic.
