OFFICIAL DIY: Converting OBDII To OBDI Using A Boomslang Conversion Harness
Discussion in 'Engine Tech / Drivetrain DIY How-To's' started by Jay Jay, Jan 22, 2006.
  1. Jay Jay
    Jay Jay Administrator Staff Member Registered VIP Registered OG Premium 5+ Year Member 10+ Year Member
    Jan 1, 1970
    5,342
    DIY: Converting OBDII to OBDI using a Boomslang conversion harness
    Applicable Years: 92-00 Honda Civic, 90-01 Acura Integra
    Difficulty: 1 out of 5
    Estimated Time: 30mins
    Converting to OBDI with the Boomslang harness is super easy as it’s a plug-n-play mod only taking about 5 minutes.
    This conversion was done on a 97 civic with a b18c1.
    Tools and items needed:
    -ODBI ecu
    -Boomslang OBD2A to OBD1 Conversion Harness
    1996-1999 Acura Integra
    1996-1998 Honda Civic
    1996-2001 Honda Prelude
    1996-1997 Honda Accord
    This harness can be had for only $75 shipped. To order one click this link http://www.boomslang.us/obd2to1.htm
    Instructions:
    Locate the passenger side kick panel and remove the cover.
    [​IMG]
    [​IMG]
    [​IMG]
    Unplug the engine harness from the ecu.
    [​IMG]
    ODBII ecu connections
    [​IMG]
    ODBI ecu connections
    [​IMG]
    Plug the engine harness into the Boomslang harness.
    [​IMG]
    [​IMG]
    [​IMG]
    Plug the Boomslang harness into the ODBI ecu and reverse the above directions to put everything back together.
    [​IMG]
    That’s it! Wasn’t that easier than hacking your stock wire harness. Now you can easily switch back to ODBII if need be.
    Big thanks to Rustin at Boomslang Fabrication www.boomslang.us
  2. nightryder99
    nightryder99 New Member Registered VIP 5+ Year Member 10+ Year Member
    Nov 18, 2004
    745
    laval canada
    im guessing this ain't to dif for the OBD2B ECU
    awesome lil harness converter...looks like good quality...I definetly gonna get one of those
  3. j_fukin_t
    j_fukin_t New Member Registered VIP Registered OG 5+ Year Member
    May 2, 2005
    4,555
    None Ya, Indiana
    :werd: so i'm also guessing there is a seperate harness for the obd2b right, and will i need ANYTHING additional i.e. o2 sensors or any diff sensors for that matter or does it all get taken care of in the harness that you purchase??
  4. $lick Rick
    $lick Rick TEOTWAWKI Registered VIP Registered OG 5+ Year Member 10+ Year Member
    Dec 4, 1984
    15,252
    oregon
    the company lists an odb2b to odb0 conversion harness
    but i dont see one for odb2b to odb1
  5. nightryder99
    Nov 18, 2004
    745
    laval canada
    what are you talking about????
    right here
  6. $lick Rick
    Dec 4, 1984
    15,252
    oregon
  7. saga boy
    saga boy New Member Registered VIP 5+ Year Member
    Mar 1, 2007
    311
    Nashville
    ok so do this pass emissions? i have asked around if a JDM H, B, or D engine thats obd1 is swaped into an obd2 car event with the jumper harness it may not pass emissions. Someone please let me know before i buy an engine!
  8. Shiznit
    Shiznit Stickin it to the Man Registered VIP Registered OG 5+ Year Member 10+ Year Member
    Apr 29, 2003
    12,532
    Arizona
    it wont pass emissions converting obd2 to obd1. youll have to run an obd2 ecu when going for the test
  9. 99SilverCX
    99SilverCX New Member Registered VIP 5+ Year Member 10+ Year Member
    Feb 15, 2005
    615
    Chicago
    For the B16A motor swap into 96-00 Civics, you can use the Y7 or Y8 engine harnesses off you stock engines. If you use Y7, you will just have to wire up the VTEC stuff. I used Y8 harness in my CX and used a BOOMSLANG harness. Made the swap 1000 times easier. I didn't have to mess with any of the wires related to the ECU, except the Alternator, I had to use the OBD1 plug on the OBD2B harness. Oh, and I had to use OBD1 Fuel Injector plugs. But you can buy the adaptors from PasswordJDM now. And I had to wire the Dizzy to work with my OBD2 harness, but PasswordJDM sells an adapter for that too now.
    So when going from OBD2 to OBD1 motor,
    you'll need these to make the swap easier:
    1. http://www.boomslang.us/obd2to1.htm
    OR
    http://www.boomslang.us/vafc2.htm if you're going with VAFC2.
    2. http://passwordjdm.com/PasswordJDM-Distributor-Jumper-Harness-P1881C320.aspx
    3. http://passwordjdm.com/PasswordJDM-Upgrade-Injector-Jumpers-P1882C320.aspx (maybe)
  10. Hallmon99
    Hallmon99 New Member 5+ Year Member
    Mar 17, 2009
    1
    Minot AFB
    So this harness converter wouldnt work for a 99 civic???
  11. Jay Jay
    Jan 1, 1970
    5,342
    If you are converting to OBD1 you would need a OBD2B -> OBD1 harness. 96-98 civics are OBD2A, 99-00 civics are OBD2B.
Loading...
: official diy
Share This Page
