OFFICIAL DIY: Ingalls Stiffy™ Adjustable Engine Torque Damper for 2002-2005 Civic Si
Discussion in 'Engine Tech / Drivetrain DIY How-To's' started by Jay Jay, Apr 10, 2006.
  1. Jay Jay
    Jay Jay Administrator Staff Member Registered VIP Registered OG Premium 5+ Year Member 10+ Year Member
    Jan 1, 1970
    5,342
    DIY: Ingalls Stiffy™ Adjustable Engine Torque Damper for 2002-2005 Honda Civic Si (93022)
    Applicable Years: 02-05 Civic
    Difficulty: 1 out of 5
    Estimated Time: 30mins
    Kit Contents:
    [​IMG]
    Tools Needed:
    • Ingalls Stiffy™ part # 93022
    • 14, 15, 17 mm sockets and open-face wrenches
    • Adjustable wrench
    Installation:
    Under the hood remove the two inside 14mm nuts that secure the passenger shock.
    [​IMG]
    Install the Chassis Mounting Bracket and tighten down the nuts.
    [​IMG]
    Remove the gold colored nut closest to the front bumper using a 17 mm socket.
    [​IMG]
    Place the 12mm washer on top of the nut on the stud closest to the firewall.
    [​IMG]
    Install the Engine Mounting Bracket and tighten down using the stock nut (17mm socket) for the front stud and the supplied nut using a 19mm socket.
    [​IMG]
    Install the Stiffy™ onto the Chassis Mounting Bracket using the supplied hardware using a 15mm socket and 17mm open-face wrench.
    [​IMG]
    The supplied o-ring is placed between the Stiffy and washer, this helps dampen road noise "feel" that can be transferred through the assembly.
    [​IMG]
    Mount the Stiffy™ to the Engine Mounting Bracket using a 15mm socket and 17mm open-face wrench. Be sure to install the washer and o-ring in the same order as above.
    [​IMG]
    That's it, your done. This is how it should look when complete.
    [​IMG]
    Product Review:
    After installing the Ingalls Stiffy™ Engine Torque Damper you can immediately notice the "stiffer" feel during start up since the motor doesn't "rock" as much. On the road you'll notice it greatly reduces wheel-hop during launches and torque-steer when running out your gears. Shifts are more precise while it does add a bit more "engine-noise" inside the cabin. The adjustable feature allows the assembly to be tuned and pre-loaded for racing and street applications.
    Big thanks to Rob over at Ingalls www.ingallseng.com
    [​IMG]
      File size:
      81.7 KB
      11,411
      File size:
      80.6 KB
      9,947
      File size:
      58.8 KB
      9,752
      File size:
      68.8 KB
      9,604
      File size:
      58.9 KB
      9,967
      File size:
      79.1 KB
      9,891
      File size:
      64.1 KB
      9,656
      File size:
      76.2 KB
      11,016
      File size:
      63.9 KB
      9,909
      File size:
      77.8 KB
      9,928
      File size:
      48.7 KB
      9,771
  2. robstamina
    robstamina New Member 5+ Year Member
    Jan 12, 2006
    9
    denver, colorado
    If any clubcivic members have any ?'s about our products please feel free to email me directly..
    robs@ingallseng.com
    also here's a link to the product on our site..
    http://www.ingallseng.com/parts/93022.htm
    it has instruction on how to install(evethough the review is personally better than the instructions) and it has a how to adjust the damper settings instructions..
    These units are factory adjusted at 16mm which is on the softer side..if you want it on the a stiffest setting that is a 10mm..
    I have one on my s/c'd 04 si and swear by it.. I have it on the hardest setting which vibrates the car a litle but I also have the esmm's that add to that.. I HIGHLY recommend the damper inconjuction with motor mounts.
    The damper takes care of he majority of engine movement from front to back(accel and decel) and the motor mounts take care of side to side movemnet(turning etc)
  3. homicydalboy
    homicydalboy vtec+turbo=no traction 5+ Year Member 10+ Year Member
    Aug 21, 2004
    190
    Washington
    Will theis product work on swaped hondas? Like the infamous Bseries swaps?
    Thanks
  4. corsport
    corsport New Member 5+ Year Member
    Oct 9, 2005
    60
    Denver, CO
    Yes they do fit the B-Series swaps --- if you used the integra drivers side mount use the Integra dampener here: http://www.corsportusa.com/store/catalog/product_info.php?cPath=29&products_id=250 --- if you used the civic drivers side mount use the appropriate year civic here:
    ek: http://www.corsportusa.com/store/catalog/product_info.php?cPath=29&products_id=30
    or here for the eg: http://www.corsportusa.com/store/catalog/product_info.php?cPath=29&products_id=34
    As a vendor here check out all our Ingalls ETD's for sale and keep an eye out for our new sales thread later today.
    http://www.corsportusa.com/store/catalog/index.php?cPath=29
    Thanks for looking,
    Tai
    CorSport
  5. corsport
    Oct 9, 2005
    60
    Denver, CO
  6. robstamina
    Jan 12, 2006
    9
    denver, colorado
    I will send you some pics of the different mounts...
    there are a couple different swap variations...integra motor mount, civic mount etc for swaps..these work on some of the aftermarket mounts too..pm Corsport what set up you have and they will get you taken care of.
    very compentiant civic people over at corsport..
  7. corsport
    Oct 9, 2005
    60
    Denver, CO
    ^thanks rob.
    Tai
    CorSport
  8. Lessen
    Lessen Stop staring at my car! 5+ Year Member
    Apr 7, 2006
    25
    Aurora, OH
    This is definatly on my summer to-do list. I can't wait to get rid of some wheel hop. It aggravated me for 3 years while I had my '02 Si.
  9. robstamina
    Jan 12, 2006
    9
    denver, colorado
    I have an 04' with a jrsc that had crazy wheel hop and torque steer.. Now the Ingalls damper and esmm's definately get rid of most of it..better shifting since the tranny is more rigid..
    mines the silver one..
    http://www.corep3.com/gallery/thumbnails.php?album=20
  10. corsport
    Oct 9, 2005
    60
    Denver, CO
  11. oc_civic
    oc_civic .................... Registered VIP Registered OG 5+ Year Member 10+ Year Member
    Oct 31, 1977
    15,398
    Perdition
    EXCELLENT write up.. good luck with the sales you come HIGHLY recomended by ingalls directly..
  12. corsport
    Oct 9, 2005
    60
    Denver, CO
    ^thanks!
    Tai
    CorSport
  13. King Bob
    King Bob The life'o Riley Registered VIP 5+ Year Member 10+ Year Member
    Aug 28, 2003
    3,566
    Houma Louisiana
    is there one avaliable yet for my fg2?
  14. corsport
    Oct 9, 2005
    60
    Denver, CO
    Actually, the FG2 has a dog bone style dampener built in from the factory --- I know its not high on Ingalls list of cars to make one for.
    Tai
  15. King Bob
    Aug 28, 2003
    3,566
    Houma Louisiana
    also have you ever looked under the hood of an fg2? you cant even see the top of the shock cause its mounted so far back in there I am dreading the day I install coilovers
  16. corsport
    Oct 9, 2005
    60
    Denver, CO
    Yep, they did their best to make that the "unmodifiable" civic.
    Short rams lose power, exhausts are sketchy at best, the ecu, etc.
    Tai
  17. Hecz
    Hecz New Member Registered VIP Registered OG 5+ Year Member 10+ Year Member
    Aug 10, 2003
    13,646
    Chicago, IL - USA
    will this work for h22 in eks??? if not, wwhere could i find one?
  18. gearbox
    gearbox New Member Registered VIP 5+ Year Member
    May 25, 2005
    1,510
    Urbana, IL
    is there a new version that fits 2001-2005 civic EX with abs? the one you have now doesn't clear the abs box but fits fine on the DX/LX.
  19. corsport
    Oct 9, 2005
    60
    Denver, CO
    What driver side engine mount are you using?
    Tai
  20. corsport
    Oct 9, 2005
    60
    Denver, CO
    We got a call about this Friday --- Rob from Ingalls is working on a solution ... not sure what it will be yet, but I will let everyone know when they figure something out.
    Thanks.
    Tai
Loading...
: official diy
Share This Page
