i
tap it for a bigger sized drain pan bolt.. then dont over tighten it when you change your oil next time :-)Okay apparently it didn't post but I did an oil change today and the oil drain bolt wouldn't tighten is if it was stripped somewhere I took the washer off the bolt and got it to hand tighten as snug as possible.....ishould I be worried ill lose it and all my oil and damage the motor, just need a temp fix to last a few months doing a swap once winter comes and goes....ne help would be appreciated thanks
