Dont mean to steal ur thread SlowEM1 but its related....
RonJ, long time..... anyways, my car started overheating about a week ago. After I drive for about 20min the temp needle goes 3/4 of the way up, NEVER to the red and it'll stay there. If I put on the fan with hot air coming out, it helps lower the temp a bit (like just above normal temp)
So I checked a few times the coolant level and its fine, the reservoir tank is filled.... So I took off the thermostat, took a drive and it still overheat about 20-30 min later during normal driving. Which leaves me to believe it must be an electrical problem or a problem with the temp sensor, IDK.
That little temp sensor on the side of the head is new (about 6k on it) but the wire that plugs to it was cut so i had to mend it (Im pretty sure I did a good job so I dont think its this)... Any ideas/suggestions? Thanks man!
