Parts Needed for B series swap into EF/EG/EK.
Status
Not open for further replies.
DarkCreep
D16Y8+T
We get these threads all day long here on CC so I thought Id make one to rule them all.
ENGINE PARTS:
-B-series motor
-Intake manifold w/ throttle body
-Exhaust manifold
-Si driver-side mount (EK Only)
-Rear tranny mount
TRANSMISSION:
-B-series Transmission
-90-01 Integra axles/99-00 Si axles
-90-01 Integra half-shaft/99-00 Si half-shaft
-94-01 Integra shift linkage/99-00 EM1 linkage
ELECTRONICS:
-ECU
-Engine harness (For VTEC motor only)
DIY LINKS:
NFR_AP2
i can help with any info for a b-series into EK chassis
oddeb707
R.I.P Stephen Jackson
Can't you just use any b series rear mount and axles?
You forgot shift linkage.
Szady
D-Series Master
For B-Series into EK, you need the rear tranny mount and timing belt side block mount off the 99-00 Si.
You can technically use a 90-93 block mount off a B18a1 into an EK, but it dosent line up perfectly. I currently am using it on my '00 sedan, and the front most bolt hole isnt PERFECTLY lined up. You can however fit a bolt thru it.
You need any 94-01 Integra or 99-00 Si shift linkage. Any 90-01 axles will work, but if you use a 90-93 drivers side half shaft, you NEED to use a 90-93 drivers side axle (same goes for 94-01 half shaft/axle).
Szady
D-Series Master
You also dont need a new engine harness. 90% of my swap (for wiring) was plug and play. Actually, come to think of it, I didnt have to do any extra wiring. Everything pluged in. If you have a DX/LX harness, you'll have to extend the TPS/MAP sensor plug, and repin the IACV. Other than that, its pretty straight foward. Just a FYI.
DarkCreep
D16Y8+T
You also need to run the VTEC and oil pressure wires and pin them into the correct slot on the harness plugs.
Szady
D-Series Master
If your swaping a B16 or B18c. If your swaping a B18a/b in, you dont.
31dev31
Chillin' Canadian Member
It would be awesome if you could clear up on what mounts will work in the EG... and for both auto and manual trannies as well.
DarkCreep
D16Y8+T
Ive never done the swap on an EG so if someone chimes in ill add it to the list.
X-aCuTiOnA
W.W.H.D.?
Some stuff I ran into on my JDM GSR swap
JDM does not require evap canister.
You need a GSR throttle cable.
JDM GSR does not have a knock sensor.
The fuel line from stock fuel filter is not straight bolt up.
Thats it so far
Status
