artythekid
Okay I'll try to make this as short and simple as possible. 97 Civic EX coupe stock D16. Problem: passenger power window stuck down. Passenger window used to work np. Now it went down wont go up. After a few days I cant even hear the motor when trying to go down. Cant hear it going up. Master switch works with driver window but not passenger. Rly need this window fixed!
So far I have checked fuses with a testlamp and all are good. I started ripping apart the door trying to find a break in any of the wire. Traced the wire from the switch, into the inner door, out the door behind the fender and into the chassis of thr car. All the wires are good and actually look clean and in nice condition.
So I guess my question is where do I go from here? Should I try buying a new passenger switch I found for 14.99? Or is it possible my window motor? Wiriing issue? What you guys think?
