please need help asap
joe1231
ok i have a ek hatch with a b18c5. on the way to work i stepped on it and after words i noticed the engine would bog out. i did not rev the engine pass the limiter. its redlines at 8400 and i always shift at 8k. any suggestion?
crash!
Avi, pull your socks up.
You ALWAYS shift at 8k? That may be your first issue...
Puma
Has no filter
Is this for real?
Sent from my ADR6400L using Tapatalk
Trekk
You need to explain the problem a little better. When does it bog out? All the time now, just that once?
crash!
It would just be ridiculous if you shifted at 8k all the time. Are you blowing smoke?
joe1231
ok when ever i step on the car. let say i step on it on the highway, then when i get off at my exit i stop, thats when i feel it bogging out. and u see the rpms drop and pick back up. then when u start going it bogs untill it reaches 3k rpms. theres no smoke whats so ever.
and yes shifting at 8k rpms all the time would be extremely crazy lol
Blood_Shot
so it ONLY doesnt this AFTER you rip on it and come to a stop then it idles/runs rough until about 3k or so is this correct
sounds like when the car is getting pushed / warm. Check o2 sensors. I had a very similar problem, car would bog down once it got warmed up, though cold would run perfect. Faulty o2 sensor.
Anyways, CEL code is Check Engine Light, yes.
joe1231
The thing is it doesn't do it everytime its warm. Its jst after I step on it
right, but when you step on it, RPM's go up, parts move faster, more heat is generated. Though your temp gauge will not reflect it because your fan comes on, your exhaust may see the temperature increase.
joe1231
Oh I see. Any certain way to be able to see if its bad
CHILD
All Day, All JDM
Bad o2 sensor, or sometimes it's a fouled spark plug. Could be other things but these are common issues.
