Power steering fluid, leaking inside cabin.
hswan1180
Hey guys... I recentlly purchaced a 2001 EX coupe It came with a PS leak and it seems like it was leaking for a long time in to the carper, because it was very stained. I do have a good idea of what i need to do, but i just wanted to see if anyone had any problems like this and what did you guys did. I will keep up as i fix it. I saw a tread in another forum but it seems like after people fix them they don tell people what there conclucion was, so here ill try to give it a proper end.:D
lethal6
Your Mom's Moderator
Power steering fluid leaking into the cabin? That's not possible. Are you sure it isn't clutch fluid from the master cylinder mounted to the firewall.
hswan1180
No, I am pretty sure is ps fluid. I cleaned the hell out of the fire wall by that area and after the water dried , actuated the steering and is coming out of the seal by the shatf installed at the ps unit. It sucks. Im debating on getting a new carpet or clean it. :eek:
Sent from my SCH-I605 using Tapatalk 2
JeffBel
I didn't think you could get ps fluid inside the cabin.
hswan1180
Here is a pic of were it is coming from,
That's the shaft from the cabin side.
Carpet out to clean the ps fluid from the drivers side.
I did slowed down the leak with some ps stop leak product but that wont hold too long :thumbup:
hswan1180
Well, it has being a couple of weeks. I was going to change the o-ring from where the leak was coming from, but I realized since the car has 175k plus miles, maybe it was a good idea to just get a fully rebuilt unit, and new inner and outer tie rods. Had to order 2 new o-rings for the inner tie rods slider and a firewall boot from honda, and all good to go. Yes I had to fight the steering rack out and in but with some patients it was good. Next day had the car aligned.
:thumbup:
No more ps fluid leak:D
chente281
So did you end up replacing the rack and pinion or did you you just get a Rack & Pinion Seal Kit.
hswan1180
Damn I lost my account login... sorry for not responding... but yes as I stated in my last entry, yes i did get a fully rebuild PS servo.
Blast from the past! :lol:
