Just replaced the fuel filter on my 99 EX and I've noticed some low-RPM stuttering, namely when slowing down to a rolling stop and gentle acceleration when coming from a rolling stop (think of a stop sign).
This was my first time replacing the filter and I followed the instructions here with the exception of putting the two washers on the bolt instead of one on the bolt and one in between the filter and hose. I started the car and it took a while to crank and then idled rough for about 2 seconds then was fine. When I saw some fuel was leaking, I realized my mistake and put the washers in the correct spots. Started again and noticed no fuel leaks.
So after taking it around the block a few times, I noticed everything was fine except when coming to a stop and thats where the mild stuttering occurs. I double checked everything and noticed no leaks anywhere...is it possible to tighten the stuff too tight or maybe it just needs a couple trips to work it out?
I'm going to let the car cool down completely and take it for a short drive later tonight to check again...
Thanks.
Thanks.
