Car - 2006 EX with ABS (about 130k miles). Has never had brake work other than pad/rotor replacement.
My brother replaced his rear pads and rotors about 20k ago. The other day, he noticed that the pads on one rear wheel are down to metal. I'm going to look at the brakes tomorrow morning but I assume the caliper is shot. Would most others agree?
Also, from the information I have found from researching, I understand that bleeding is not effected by ABS so I don't have to worry about doing anything different, correct?
Lastly, since I will only be opening one brake line and will not be running the MC dry, only bleeding one wheel should not be an issue correct? But since the fluid has never been replaced, I may suggest to my brother that we bleed the entire system just to get new fresh fluid in. We'll see.
Thanks in advance.
Thanks in advance.
