rack and pinion or inner tie rods? how to differentiate?
Discussion in '6th Generation Honda Civic (1996-2000)' started by fabster, Oct 9, 2017.
  1. fabster
    fabster New Member 5+ Year Member 10+ Year Member
    Feb 17, 2006
    11
    CT, USA
    Hi all,
    I've searched and didn't find a post that is related to diagnosing. I have play in my steering both parked and driving. I've done a check on both wheels off the ground and I see play in both inner tie rods in addition to no grease in both boots. How can I know if I should just replace both inner tie rods or the whole rack and pinion? Is it a good assumption that if both have play it's the R&P or not necessarily? I've also heard of adjusting the R&P, when is that in order? Thanks!
  2. boofoo
    boofoo Respected Registered VIP
    Oct 15, 2016
    2,235
    United States
    If the rack is not leaking PS fluid, start by replacing the loose inner tie rods and the boots. Then go from there.
  3. fabster
    Feb 17, 2006
    11
    CT, USA
    boofoo,
    Thanks. That's fair and helpful. I don't have power steering fluid leaking. So the fact that both inner tie rods have play don't seem to suggest to you that it's the rack and pinion itself? I figured inner tie rods likely go out at different times instead of as a pair. I'd appreciate thoughts on this. Thanks!
  4. boofoo
    Oct 15, 2016
    2,235
    United States
    Sounds like an inner tie rod problem.
  5. fabster
    Feb 17, 2006
    11
    CT, USA
    I'll keep you posted. Thanks!
  6. fabster
    Feb 17, 2006
    11
    CT, USA
    as an update I went ahead and replaced both inner and outer tie rods on both sides. It wasn't too difficult. However, I still have some minor play which probably points to the rack and pinion but it's much better.
  7. boofoo
    Oct 15, 2016
    2,235
    United States
    Are you rack mount bolts loose? Start there.
Loading...
Share This Page
