Radio turns of then on, need help!!
dj_hallucn8
"to punish and enslave"
I installed my aftermarket radio in my car (a crappy Jensen was already in there) & after 2 weeks the radio would turn off then on, it happen intermittently but now if I change my foot to the brake it does it, not always but most of the time, I looked at the wiring diagram for my 96 Civic LX & I'm wondering if a wire is being pinched by the brake or gas pedals, I have already rerouted the power, memory & ground wires, replaced all interior speakers, the only thing the radio harness has connected is just speakers which might be the issue with a broken or pinched wire, I may need to reinstall all the speakers from scratch & see if the problem persists, let me know what you guys think, thanks!
dj_hallucn8
BTW it is supposed to say "off" not of in my title & I can't edit it.
leothelion
d:p
i see you live in florida, could it be that your stereo is just overheating? Its also possible that you just have a wire lose somewhere, does the whole unit lose power? Does it come back on or do you have to turn it on?
Solder and shrink wrap are your friends.
dj_hallucn8
Nope not overheating, it happens when I first back out of the driveway sometimes, it doesn't completely lose power, all of the setting & stations stay just goes off the right back on & sometimes it happens when I hit the brakes or gas pedals so I'm going with loose or broken wire but not in the dash, it's got to be near the pedals.
I solder & shrink everything, no electrical tape or twists, homie don't play dat!
dj_hallucn8
Like I said, all of the main power wires to the radio are from different sources other than the harness in the dash, tested the voltages & everything is fine there, it's got to be a speaker wire grounding out, that's the only thing still running through the factory harness.
dj_hallucn8
I checked today my battery connections & cleaned them, checked my ground wires in the engine compartment & cleaned them with a wire brush, & took a drive, within the first 10 minutes of my drive the radio cut off twice, seems like when I let off the gas to brake it does it, it doesn't always happen, I Might try a different head unit to see if that fixes it.
dj_hallucn8
Different HU & still the same results, I'm at a loss here, answers for this are hard to find.
dj_hallucn8
Well I have an update, when I turn the key over just to listen to the radio I put my foot on the brake or turned on the head lights the radio turned off then back on just like when I'm driving, so It's in the eletrical somewhere, I checked the harness under the intake maifold & found no broken or burnt wires but noticed the harness itself not connected together & have caps on the ends but I don't know why they are like this, are they supposed to be connected? I wonder if my ELD (Electric Load Detector) is going bad?
soon2bsick
mine does the same thing but usually only when I don't have the car started (just on acc) or I have my music up way loud. Mine is battery related, your's could possibly be? I have an amp & two subs and my lights dim as expected. Also I'm going to do the big 3 upgrade as well... how old is your battery?
dj_hallucn8
From the date code on the battery it's only 8 months old, I'm going to redo the grounds first to see if that helps, I have no amps or subs yet, waiting till this issue is fixed, I really think it's the ELD in the hood fuse box, the lights dim even when the car is running, #15 fuse in the dash panel is good & the wiring behind the inake manifold seem to be in good shape, also might be the regulator on the alt but from what I have read online most likely the ELD.
dj_hallucn8
Went to the junkyard today & picked up 3 ELD's, 2 are from 96-98 civics & 1 is from a 97 integra, they all look the same, just pulled them out of fuse boxes & they didn't charge me for them at all, I also got a third brake light lens because mine is looking bad so they charged me $5 for that, I also pulled some 80 & 100 amp fuses just to have extra, it's raining here now so I will have to wait till tomorrow to give my results.
dj_hallucn8
Well the ELD might have done the trick but I also upgraded both ground wires under the hood, still need to do the alt wire to battery but I'll do it tomorrow, my lights don't dim at idle when I press the brake even with the radio turned up & ac on. I will do some night driving to make sure & report back, but so far so good.
dj_hallucn8
Alright, I drove the car for an hour with the radio turned up, AC on, iPhone plugged in, & lights on, I am happy to say my problem is fixed. It was the ELD that was acting wonky so this new one fixed my issue, also helps I upgraded my main grounds as well, so far so good, I'll know better when I hook up my sub & amp, then we will see how it does, that update will be coming soon.
dj_hallucn8
well its past tomorrow got anything new
Well in the above post I state the the problem is fixed, I have not installed amps yet, that is a weekend job & I'm a stay at home dad, I can only work on my car during my son's naps, at least I have a garage to pull the car in if it rains like it will today. I will update my progress when my amp & sub are installed.
dpt0415
check to see if it grounded correctly. mine did the same thing. i live in florida too. I even went and replaced my headunit thinking that there was something wrong with it. I checked the wires and IT WASNT GROUNDED AT ALL. >:(
