Reference: D Series Cam Specs
kellog
for all of you out their that dont have money to plop down on a swap, heres some d sereis cam specs.
Crower
D16Z SOHC VTEC (92-95) 244 / 228 208 / 192 384 / 370
D16Y SOHC VTEC (96-up) 246 / 230 208 / 191 393 / 369
Stock replacement. Excellent for automatics and mild turbo on the street with no other modifications. Idle to 7000+ rpm. 250 /
230 210 / 192 387 / 370
Stage 1 - Features far more agressive ramp rate then stock with added duration. Excellent for turbo and nitrous. Idle to 7200+ rpm. 259 / 235 224 / 196 405 / 383
Stage 2 - Designed specifically for turbo charged and supercharger applications. Features short duration and high lift. Requires springs and retainer kit 260 / 238 222 / 200 430 / 428
Stage 2 - Street/Strip with slight lope at idle due to increased primary and secondary lobes. Requires 84166 kit. 900-7500+ rpm. 276 / 255 230 / 204 427 / 432
Stage 3 - Race cams requires cylinder head modifications and ECU tuning. Requires 84166 kit. 1000-8000+ rpm. 284 / 260 236 / 216 441 / 457
Skunk2
D16Z 1.6L SOHC VTEC Stage I IN. 0.470, 240; EX. 0.445, 240 305-05-0100
D16Y8 (still looking)
Zex
D16z6 VTEC INT. EXH. VTEC INT. EXH.
Advertised Duration 256° 252° 260° 268°
Duration @ .050 214° 210° 220° 216°
Max Valve Lift .440 .400 .455 .430
Centerline 103° 111° 107° 111°
Lash .007 .009 .007 .009
Type 105100 105300
D16y8 VTEC INT. EXH. VTEC INT. EXH.
this is all i could think of off the top of my head and at 2 in morning will continue later.
Declectic
SeanJohn1802
Good info :thumbs up
*stickied* anyone else with more d-series cam info, please add it in here for all the single cammers out there
Exospeed*com
exospeed.com
Exospeed Racing Camshafts
D16A6
Street A6: Dur@.010 (int 256 exh 252) Lift (int392 exh 376)
SR909: Dur@.010 (int 272 exh 258) Lift (int400 exh 392)
Race A6: Dur@.010 (int 272 exh272) Lift (int 400 exh 400)
Stg4: Dur 282 Lift 410
Stg5:Custom Dur 300 lift 450
D16y8/Z6
SV909: Dur @010 (int 300 exh 270) Lift (int400 exh 380)
we also have LS nonvtec DOHC, ZC dual cam, and F22A camshafts available.
Wil
importlegions
1 god, 1 life,1 choice
do u have cams for the crx si (16 valve non vtec)
massivespeed
Massive Speed System
would it help?
hey all would it help me any to put a crx si 91 head and cam on my lx sedan.? im also doing the mpfi swap..thanks in adv.
dave
Ravage70
find the cam specs for the d15b vtec
they are the most aggressive oem cam for the d
zeb
JDM yO!
hmmm so is the cower stage one cam good!!!! for d series!!!
1337 | RCE
teh broke enthusiast
i have a stock D16Y7, about how much of a gain would i see with a new cam. i don't know anything about them so maybe someone could suggest a good one for me. thanks!!
00civic24
it all depends on how good it is tuned. also i have a question ifi were to get a crower stage 1 cam i would not need to gte a different ecu would i?
jokenfu21
i have jg 301 cam. is that a godo camshaft?
edog728
Bumpin' this thread cause i'm lookin' for a d series aftermarket camshaft.... could ya give out links and opinions on parts.... i'm searchin' too....
i don't have a turbo or anything. just full exhaust and intake manifold, if tis helps..... thanks....
fourstarcivic
ive got a crower stage 2 cam and i have noticed that the numbers on the cam card are more impressive than the numbers posted on the site. this is true for another one of my friends with the same cam
J18 RSA
driving god ha ha ha ha
what can i get for mine
I need tuning bit's for my uk spec EJ6 civic coupe i think in the us it is a DX it has the D16y7 engine in it what cam would you recomend for it and does anyone do anything for it
420GREEN
Anyone got the specs on an 1.6 SOHC VTEC ZC cam?? Just wondering if I got to change it to the Z6 to pass smog..........
panadol
JDM 1.5 Vtec
Hey guys, I have a D15b Vtec JDM engine and I just wanted to know if anyone has info or would suggest changing the cam to something else. Everywhere I read, they said that the stock cam is good. I was thinking to boost the car but i don't know if to change the cams or not.
Oh, and one other thing, would the d16 cams fit on a d15?
