Reference: Differences Between B16A Motors
Discussion in 'Engine Tech / Drivetrain DIY How-To's' started by NOFX, Nov 7, 2005.
Thread Status:
Not open for further replies.
  1. NOFX
    NOFX I'm NOT eran! Registered VIP Registered OG 5+ Year Member 10+ Year Member
    Nov 17, 2003
    17,061
    B16A Motor Guide - Describing the Differences
    by pissedoffsol on HondaSwap.com
    There are four general classifications for B16A motors.
    Code:
    - B16A SiR
    - B16A SiR II
    - B16A2
    - B16A3
    It is often confused as to which motor is which. In this article, we will help you pick out the clues as to which motor is which, and which one you should get for your B16 swap.
    Although I just noted that there are four classes of B16A's we can break that list down into two groups.
    Our new grouping of B16A motors:
    Code:
    - B16A SiR
    - B16A SiR II, B16A2, B16A3
    Why this breakdown?
    It all comes down to OBD. OBD, or on borad diagnostics, are broken down into levels, based on the years they are instated. The B16A SiR, commonly and mistakenly called the B16A1, is an OBD-0 motor. This was the first level of OBD installed on motor ethicals. The other three are either OBD-1 or OBD-2 motors.
    The SiR was designed for a 4th gen chassis. It works great with an '89-'91 Civic. However, try putting this motor in a '92+ Civic and the problems will just start to flow. The tranny on the SiR is cable. The 5th gen chassis uses hydralic actuation.
    Why is the SiR cheaper?
    It's cheaper for several reasons. First, it's older. Second, the A2/A3/SiR II have a higher demand as they work in newer cars and have a higher output.
    How to tell the difference between an SiR and an A2/A3/SiR II
    - SiR uses a cable tranny - 5th gens are hydraulic.
    - SiR has a lower compression ratio, 10.2:1 and makes 160ps.
    - A2/A3/SiR II have a higher compression ratioon at 10.4:1 and make 160hp (A2/A3) or 170ps (SiR II).
    - A2/A3/SiR II motors have a better cam profile.
    - A2/A3/SiR II have better oiling functions, keeping things better lubricated.
    - SiR has cast aluminum oil spray bars while the A2/A3/SiR II are made of extended aluminum.
    - A2/A3/SiR II have a single-4-wire O2 sensor instead of 2-single wire O2 sensors.
    - A2/A3/SiR II MAP sensor is an integral part of the throttle body, not an external one with a tube.
    - A2/A3/SiR II harnesses are grey, SiR has cream colored ones.
    - SiR is PGM-F1, clearly labled on the intake manifold, and A2/A3/SiR II are MPF1.
    - SiR valve covers have "DOHC" written in a larger font size than "VTEC".
    - A2/A3/SiR II valve covers have "VTEC" written in a larger font size than "DOHC".
    Code:
    [b]-------------------------------------------------------------------------------
    Chassis		Block		Head		Transmission		HP/
    Code		Stamp		Code		Stamp			CC
    --------------------------------------------------------------------------------[/b]
    DA6		"B16A 1xxxxxx"	PR3 '88-'91	S1 or J1		160
    DA8						Cable type Clutch	10.2:1
    EF8		"B16A 5xxxxxx"	PR3 '89-'92	Y1 or YS1 Cable	160
    EF9						Opt. 'LSD' stamp	10.2:1
    						on casting
    EG2		B16A		PR3 '92+	Y21 Hydraulic		170
    EG6						type Cluthc		10.4:1
    EG9
    EK4
    Additional Information
    '88-'91 B16A's are known as the SiR 1. It uses OBD-0 ECU's and cable trannys. The engine serial number is usually 1xxxxxx. '92+ B16A's are known as the SiR2. It uses OBD-1 or OBD-2 (2b), and hydraulic trannys. The engine serial number is usually 5xxxxxx.
    The #'s at the end of the block code tell where the engine originated from. The Americas, Europe, Australia, etc..... ALL Japanese engines generally do not have a number after them. (** see below). SO, if you have a B16A1, 2, 3, 4, or 5, it is usually NOT a true JDM engine. Don't mistake a B16A1 as being a cable unit, because it could be hydraulic. There are other ways to tell what year it is exactly.
    ** NOTE: There is ONE exception to this rule. In '90-'91, the Civic/CRX SiR came with a B16A1, but they are SUPER rare, and came with 160HP with 10.4:1 compression. Their counterpart of the same year was a 158HP, 10.2:1. They are very difficult to tell apart.
    Which motor is for me?
    If you are swapping into a 4th gen, the SiR is the best choice. If you are swapping into a 5th gen, the SiR II or B16A3 are your best choices. If you are swapping into a 6th gen, the B16A2 is your best bet. Using that method above, wiring will be much easier, and it's more of a direct swap than any of the others.
    Also, please check local laws before purchasing any motor. California and other states are very strict about swaps. Know what is legal and what is not before hand and save yourself the hassle.
  2. imbcruz
    imbcruz ItsMeBraulio!! Registered VIP 5+ Year Member 10+ Year Member
    Jul 19, 2005
    1,523
    South Jersey
    Pretty good stuff :thumbs up:
  3. Maiku
    Maiku What's up my Ninja?! Registered VIP 5+ Year Member 10+ Year Member
    Sep 3, 2004
    2,092
    Lake City, Florida
    Nice.
  4. 3polx
    3polx New Member 5+ Year Member
    Oct 17, 2006
    2
    manila
    nice info!!!
  5. fittedsickness
    fittedsickness New Member 5+ Year Member
    Nov 16, 2006
    8
    The Bay Area, California
    good ish. = )
  6. ACUWEEZY
    ACUWEEZY New Member
    May 31, 2010
    8
    albany new york
    Real Truth keep it coming
  7. rey_boricua
    rey_boricua 2000 EM1 B16A2T Registered VIP 5+ Year Member 10+ Year Member
    Oct 17, 2003
    2,241
    Houston, TX
    thanks for the info
  8. Klutch.ED6
    Klutch.ED6 New Member
    Feb 18, 2015
    5
    Pennsylvania
    Great set-up.
Loading...
Thread Status:
Share This Page
