Weird..... I HAD posted up some of these tranny specs before. I'm pretty sure I didn't delete it, but I can't seem to find it. Some of it might be posted twice or three times in this thread now. I'm too tired to go through it all right now. Anyway, so here;s some more. (I made my own thread because the info is generally at the beginning of the thread. I'm trying to lessen confusion.
The following was sourced from another site that I can't remember right now. I think pissedoffsol did it though.
SOHC tranny specs
4G 88-91 USDM
5G 92-95 USDM
5G 92-95 USDM
6G 96-00 USDM
Honda Tranny Gear Ratios: D Series
** To ID : Look by the fill plug. You'll see a circle cast into the housing.
P20-A000 = DX,CX,VX trannys
P20-B000 = Si,EX trannys.
*** 0.750 Si HB & Del Sol Si / 0.702 for 2dr & 4 dr
**** 4.058 HB / 4.250 Sedan & Coupe
SOHC tranny specs
4G 88-91 USDM
Code:
tranny gear ratio HF M/T DX M/T Si M/T A/T[/b]
1st 3.250 3.250 3.250 2.705
2nd 1.650 1.894 1.894 1.560
3rd 1.033 1.259 1.259 1.027
4th 0.823 0.937 0.937 0.780
5th 0.694 0.771 0.771 -----
REVERSE 3.153 3.153 3.153 1.954
FINAL DRIVE 2.954 49st 3.888 4.250 3.933
3.250 Ca.
Code:
tranny gear ratio M/T D15B8/D15Z1 D15B7 D16Z6[/b]
2nd 1.761 1.761 1.900
3rd 1.066 1.172 1.250
4th 0.852 0.909 0.909
5th 0.702 0.702 0.702
FINAL DRIVE 3.250 3.888 3DR 4.250
4.058 4DR
Code:
tranny gear ratio A/T D15B7 D16Z6[/b]
1st 2.600 2.600
2nd 1.468 1.468
3rd 0.975 0.975
4th 0.673 0.638
REVERSE 1.954 1.954
FINAL DRIVE 4.333 4.333
Code:
tranny gear ratio D16Y5 D16Y7 D16Y8[/b]
2nd 1.782 1.782 1.909
3rd 1.172 1.172 1.250
4th 0.909 0.909 0.909
FINAL DRIVE 3.722 3.722 3DR 4.250
4.058 2DR
Code:
[u]Year/ Make Market Type Tranny code 1st 2nd 3rd 4th 5th Reverse Final Drive Notes[/u][/b]
ZC sohc from a JDM Cable L3 3.250 1.894 1.259 0.937 0.771 3.153 4.250
36i sedan (Civic
[u]shuttle with 2WD) [/u]
ZC Sohc (MPFi JDM Cable L3 3.250 1.894 1.259 0.937 0.771 3.153 4.437 / (4.25 for ZX carb)
and Carb) from (LSD was optional on the 92-3 MPFI models which came with SS0 sticker)
[u]ZXi/RXi/ZX [/u]
ZC DOHC from JDM Cable L3 3.250 1.944 1.346 1.033 0.878 3.153 3.888
[u]88-91 civic Si/Si Extra (LSD optional) [/u]
[u]88-91 Civic STD USDM Cable L3 3.250 1.650 1.033 0.823 -- 3.153 3.888 [/u]
88-91 Civic DX USDM Cable L3 3.250 1.894 1.259 0.937 0.771 3.153 3.888
[u]LX / CRX [/u]
88-91 Civic Si USDM Cable L3 3.250 1.894 1.259 0.937 0.771 3.153 4.250
[u]/ CRX Si [/u]
[u]88-91 CRX HF USDM Cable L3 3.250 1.650 1.033 0.823 0.694 3.153 2.95 / ( 3.25 for the CA)[/u]
92-95 Civic DX USDM Hydro S20 3.250 1.761 1.172 0.909 0.702 3.153 4.058
[u]LX / Del Sol S** [/u]
92-95 Civic Si/ USDM Hydro S20 3.250 1.900 1.250 0.909 *** 3.153 4.250
[u]EX / Del Sol Si** [/u]
[u]92-95 Civic CX/VX** USDM Hydro S20 3.250 1.761 1.066 0.853 0.702 3.153 3.250 [/u]
[u]96-01 Civic DX LX USDM Hydro -- 3.250 1.782 1.172 0.909 0.702 3.153 3.722 [/u]
[u]96-01 Civic HX CX USDM Hydro -- 3.250 1.782 1.172 0.909 0.702 3.153 3.722 [/u]
[u]96-01 Civic EX USDM Hydro -- 3.250 1.909 1.250 0.909 0.702 3.153 **** [/u]
[u]02 Civic DX LX USDM Hydro -- 3.462 1.870 1.241 0.970 0.711 3.231 4.111 [/u]
[u]02 Civic HX USDM Hydro -- 3.461 1.750 1.166 0.857 0.710 3.230 3.842 [/u]
[u]02 Civic EX USDM Hydro -- 3.143 1.870 1.241 0.970 0.757 3.231 4.412 [/u]
