Revisiting a CEL issue..
Discussion in '7th Generation Honda Civic (2001-2005)' started by RayES2, Oct 28, 2017.
  1. RayES2
    RayES2 New Member
    May 5, 2014
    4
    Germantown, MD
    I have an ES2 with a D17A2 with a CEL and rough running issue.
    Replaced the following so far per regular maintenance; all items are less than 5 months old:
    Coils (DENSO)
    Plugs (NGK)
    A/f ratio sensor (DENSO)
    02 sensor (NTK)
    EGR Valve with new gasket
    Cleaned EGR Passages
    Inspected for vacuum leaks
    Inspected injectors; no clogs, clean and like new spray pattern
    changed thermostat and did a coolant flush
    did valve cover gasket with spark plug tube seals and cam plug
    both injector base and plenum gasket were done with t/b gasket
    Compression and leakdown tests show no failure of piston rings and head gasket, compression was 200 in every cylinder from what the tech told me. Tech found no leaks.
    codes are p0300, p0301, p0302,p0303 and p0304.
    anyone else able to chime in and give me an idea what it may be?
  2. boofoo
    boofoo Respected Registered VIP
    Oct 15, 2016
    2,223
    United States
    Is the fuel in the tank very old?
    Have you measured the fuel pressure?
  3. RayES2
    RayES2 New Member
    May 5, 2014
    4
    Germantown, MD
    Fuel is always fresh and fuel pressure is good. I'm beyond baffled by this point, really.
  4. boofoo
    Oct 15, 2016
    2,223
    United States
    How did you measure the fuel pressure and what were the numbers?
  5. Youngsoulja2
    Youngsoulja2 New Member
    Sunday
    11
    WarsawIndiana
    Your Catalytic Converter could be bad.
Loading...
Share This Page
