jar25201
I bought a used control arm to replace my bent front right lca and can not get the broken bolt with splines on it to come out of the sub-frame/2nd lca piece. Its the bolt on the ball joint end.
Is there a special "right" way to remove these? Are the bolts heated and pressed though? If I can get it out should i use a regular bolt replacement or go to Honda and try and get a oem bolt replacement?
