dlb
i have a 92 VX that the previous owner put a mini me (d15b7 block/d16z6 head) into. i noticed a big of pinging when going up hills at around 2000 rpm so i checked the timing and it's advanced quite a bit (my timing gun is cheap and doesn't give advance specs). i followed these steps
http://www.justanswer.com/honda/0il4i-set-timing-93-civic-vx-vtec.html
but i checked the timing both with and without jumping the service check connector, both before and after i adjusted the timing, and saw no visible difference between the two. so my question is: when you jump the connector, should there be a visible change in the advance?
