Squealing when air conditioner is on
joenobodyyet
1997 Honda Civic LX manual transmission
When I'm driving and turn my air conditioner on, there is a squealing under the hood. The squealing does not last long, and I think it only happens when I'm accelerating. I don't really notice it after a few seconds and it seems like it was much worse two weeks ago. There is no squeal when the Air conditioning is off.
I'm going to get some new belts but I was wondering if I should order some other replacement parts before I do the fix, just in case I find that I need something else. What other parts may be worn out? Tensioner? Pulley? Bearings? Bracket? I believe I need a new AC belt but I'm not too knowledgeable about any other issues that might need addressing. Please send images or links so I know exactly what parts to purchase. Thanks!
710times
Tighten the belt. I would try that first
When you go to change the belt your gonna have to pull off the torque mount that goes around the ac belt. So I would try the easier thing first.
Sent from my SM-G900T using Tapatalk
Enzetsu
I've got the exact same problem i just can't loosen that stupid bolt on the tensioner so good luck!
