A strut bar does do something to the 7th gen. A strut bar will make a difference on any car that doesn't already have a strut bar. Just because a chassis design gets better (generally speaking) with newer models, doesn't mean that there isn't room for improvement.well like i said since the strut bar basically does nothing to the 7th gen Neuspeed is the best bet. does Carbing even make a 3 point strut bar for 7th gens because ive never seen one before.
Pull that crap ass d17 out and swap the subframe to a rsx subframe and boom, everything from the rsx can swap right over. So your front lower half will handle like a rsx, leaving all the flex on the upper portion which could use some chassis bracing (a rsx-s comes with a front upper shock tower bar....i wonder whyHow so child? (Adjusts glasses)
I learned today. LolPull that crap ass d17 out and swap the subframe to a rsx subframe and boom, everything from the rsx can swap right over. So your front lower half will handle like a rsx, leaving all the flex on the upper portion which could use some chassis bracing (a rsx-s comes with a front upper shock tower bar....i wonder why
