Use the k24 block and the k20 headThis car has a d15b non vtec which had done it's time. Need opinion for which is the best option for new swap. Options at hand are k20 a/t, k24a cl9 m/t. Both are half cut accords so can get ecu wiring etc. Can anyone suggest that will any of two even fit into this car?
Head over which block?Faster and easier install would be a D16z6 for just a little pep in your step, but if power is what you are looking for then the k24 and k20 head would be an excellent choice
Shall prefer auto or manual on the given space.Use the k24 block and the k20 head
Sent from my LGMS631 using Tapatalk
What are you asking I didn't get your question? But manual for life lolShall prefer auto or manual on the given space.
Tbh you'll probably get the most 2sec with a auto but to me I'm not gonna go spend all that money on a auto trans and it blow up when you can get a manual and say for example 2ns gear go out replace it with another hinds gear from any k20 or k24 trans manual is better and simplerThere is a debate on this. Some say tuned automatic transmissions are faster, and some say manual transmissions are faster. My opinion is definitely manual transmission. Way more fun to drive and easier & cheaper to fix and find a replacement if necessary
Without much thought, bought a k23a3 with ast5 6 speed manual. ECU and meters with whole wiring taken out from a cl9 half cut. cost around 2000usd. Hope it fits in fine. Couldn't figure out the actual specs for it though.There is a debate on this. Some say tuned automatic transmissions are faster, and some say manual transmissions are faster. My opinion is definitely manual transmission. Way more fun to drive and easier & cheaper to fix and find a replacement if necessary
Steering gear as in your power steering?Dear, having been able to place a k24a3 in my civic. Do I need to bother about the steering gear?
