This is "MY BUILD" INSPIRATION
203CT
Slow But Not Low
Performance:
-2.5" Exhaust to Vibrant Muffler
-4-2-1 Header
Interior:
-Password JDM: Shiftboot
-Blox Special Edition Noechrome shift knob
-Red Door Panels & Armrest
Exterior:
-OEM Honda 99-00 Mud Guards
-OEM EM1 Front Grill
-OEM Honda Fit Front Lip
Suspension:
-Function and Form Type I Coilovers
-Function7 Lower Control Arms
-ASR Subframe Brace
-ASR 24mm Sway bar/ASR Spherical Endlinks
-Benen Polish Rear Lower Tie Bar
-Energy Suspension T/A Bushings
-Buddyclub P1 Rear Camber Kit
Wheels:
-15x6.5 Rota Polish Slipstreams
-205/50-15 Nitto Neogen tires
-EM1 Front and Rear Spindles
-Stop Tech Blank Rotors w/Ceramic Pads
-Russell Stainless Braided Brake Lines
K-Swap Part List
ENGINE
•2006 K24a2 [emoji818]️
•K20 transmission
•Wire harness
•Charge harness
•Competition Stage 4 Clutch [emoji818]️
•Competition Ultralight Flywheel[emoji818]️
•Half shaft
•Alternator [emoji818]️
•K20 Starter[emoji818]️
•RSX Type S Denso O2 sensor[emoji818]️
•RBC Intake manifold [emoji818]️
•P2R Intake manifold gasket[emoji818]️
•Throttle body
•RDX Injectors w/clips[emoji818]️
•RSX Type S Oil Pump Conversion[emoji818]️
•K-Tuned Throttle body gasket[emoji818]️
•Kpro
SWAP PARTS-
•Acura GSR throttle cable [emoji818]️
•Eg Subrame & forks w/Steering Rack [emoji818]️
•Hasport EKK2 Engine Mount Kit [emoji818]️
•Hybridracing Conversions harness [emoji818]️
•Hybridracing Swap ground kit[emoji818]️
•Hybridracing Clutch line [emoji818]️
•Hybridracing Swap radiator hoses[emoji818]️
•Hybridracing Race shifter cables [emoji818]️
•Hybridracing 3" cold air intake [emoji818]️
•K-Tuned Brake Booster Line Kit [emoji818]️
•K-Tuned Fuel rail [emoji818]️
•K-Tuned Fuel pressure regulator [emoji818]️
•K-Tuned Fuel pressure gauge [emoji818]️
•K-Tuned Temp sensor w/adapter [emoji818]️
•K-Tuned "Tucked" fuel lines [emoji818]️
•K-Tuned Billet Shifter [emoji818]️
•K-Tuned Billet Shifter base[emoji818]️
•K-Tuned Billet Shifter base bushings [emoji818]️
•K-Tuned Billet Shifter gourmet [emoji818]️
•K-Tuned AC/PS delete kit[emoji818]️
•K-Tuned Throttle body adaptor[emoji818]️
•K-Tuned Radiator bracket [emoji818]️
•Insaneshaft 32mm swap axles [emoji818]️
•Skunk2 Alpha series radiator [emoji818]️
•12"Slim fan[emoji818]️
•Type S Knock Sensor
•PLM Hytech rep 4-2-1 header [emoji818]️
•Flex pipe
•Heater hoses
•OEM Honda CRV engine bracket [emoji818]️
Latest picture of the car
Robin...
D-Series Soldier
Not bad man, they bay needs some love though, good luck...
203CT
Slow But Not Low
Yea I'm going to tackle the dirt and grim soon. It's been raining a lot so I couldn't get around to it. I'll be hitting up CHILD for some tips on getting this bay in order.
Robin...
D-Series Soldier
I was about to mention on how he did it but you beat me to the punch...:lol:
mymmeryloss
RHD is where its at
What are ur plans? Keeping the 96-98 front i hope!
Sent from my Butthole using Fart power!
203CT
Slow But Not Low
I'm still debating I like 99/00 but I think I want to try the sir bumper molding before I do a 99/00 conversion. At least I'll be different tht way... But I feel like if I do the sir I have to go all out with edm parts which are rare, hard to source not to mention expensive.
203CT
Slow But Not Low
So yesterday afternoon my diver side window came off track and I was stuck with a open window in crappy weather. I manage to get the door panel off and remove the glass from the bracket that moves the glass up and down and take the whole thing out. While I was in the door I notice that the moisture barrier was ripped out. I'll have to look into replacing that. But I manage to get the glass back on track and put things back in the correct order all before it rain =)
203CT
Slow But Not Low
Okay so today I decided I would start the battle with the grease in the engine bay. Overall I got a lot done but I still have a lot left to tackle. I mostly focused on the underside of the hood and the radiator support. Here's how it sits now.
ImageUploadedByTapatalk1340752475.583664.jpg ImageUploadedByTapatalk1340752689.026414.jpg ImageUploadedByTapatalk1340752714.711679.jpg ImageUploadedByTapatalk1340752724.340545.jpg ImageUploadedByTapatalk1340752770.358399.jpg ImageUploadedByTapatalk1340752789.067001.jpg
B16Ferio
Lookin clean! I would have kept the 4 door, but im a 4 door guy. otherwise this looks like its gonna be a sick build and im in for the show! Good luck man! and i find it amazing how different removing some grease from your bay can make the car look!!
203CT
Slow But Not Low
Thanks man. I plan to take my time and do as much as I can the right way. This is my first build and until I get another car to DD I have to choose my mods wisely. But I just got home from a local meet here what little pics I took.
ImageUploadedByTapatalk1340771620.791472.jpg ImageUploadedByTapatalk1340771632.862086.jpg ImageUploadedByTapatalk1340771646.607941.jpg ImageUploadedByTapatalk1340771657.569431.jpg ImageUploadedByTapatalk1340771676.650835.jpg ImageUploadedByTapatalk1340771770.694911.jpg
ImageUploadedByTapatalk1340771688.955298.jpg ImageUploadedByTapatalk1340771700.320841.jpg ImageUploadedByTapatalk1340771711.258991.jpg ImageUploadedByTapatalk1340771723.847235.jpg ImageUploadedByTapatalk1340771736.313600.jpg ImageUploadedByTapatalk1340771748.584503.jpg
A race was gonna go down after but the cops where waiting at all the spots but at least I got to get it up to 7k fleeing from the boys. Man does it feel great when u shift into second. I've been missing out so much.
B16Ferio
Im moving to where you live!!! I wish i could see cars like that where I live! although i did see a pretty nasty trans am yesterday, loud cams and exhaust with some fat tires...hahaha
203CT
Slow But Not Low
Cars are I big thing here...there's meets almost everyday from imports to classic cars...corvette owners even have their own weekly meets. CTSUBIES does it big all the time for car shows as well as my club CtVtec.
203CT
Slow But Not Low
So I've been looking for a shop locally to see how much it would cost to resurface my flywheel. I found three shops so I'll check them out tomorrow or this weekend. I'm buying the clutch from Justin here on CC I'm going with the Exedy OEM clutch. While the tranny's out I'm going to try to clean up the bay some more. I'm hoping to tackle this next weekend.
203CT
Slow But Not Low
Okay so I checked out one of those shops and its gonna cost me $40 to resurface my flywheel and they have the clutch I want for $120 so :woot: for saving a couple bucks. I'll get the clutch tuesday and tackle this job next weekend hopefully. I'm going to repaint my wipers this weekend and hopefully get back in the bay to clean some more. BTW what are you guys using to do your wipers?
zachkelly
nice man, but the first time I did my wipers I just used flat black paint and it sucked... it chipped off after a few months. Last month I used black Plasti-Dip and it seemed to work really good. Not as smooth looking but no chips yet, so it might be worth checking out!
203CT
Slow But Not Low
Okay thanks man
203CT
Slow But Not Low
Okay so today I discovered that my cars burning oil faster then a fat guy drinking a cold glass of milk on a hot summer day. And I'm getting a lot of smoke from my muffler. All arrows are pointing towards my valve seals. My question is do I need to take off the head to change them? If so I am going to replace the head gasket while it's off. But if it doesn't have to come off it's not.
96 DX Hatch
Alex
For starters, what color smoke is coming out of the exhaust?
Blue= oil
White= coolant
Black= excessive gas
If you're seeing white, you should look into a coolant pressure test. Could be due to head gasket
If you're seeing blue, you should look into the valve stem seals. I think just the valve cover needs to come off for that, but even if I'm wrong, might as well replace the head gasket if you have it on hand while you're tearing into it a little
