dorkfish
I'm confused a little ....
doing a HG , water pump, belt sap ect. I had everything aligned at TDC before disassembly.so I thought, now that Im ready to assemble I need info.
When I aligned TDC the cam sprocket was in the "up" position with the lines on the sprocket aligned with the top of the head
the Crank gear line was aligned with the arrow on the engine
Now that Im ready to install I notice on the back cover behind the cam sprocket there are arrows I assume 'are for the timing on cam sprocket TDC
this does not let the sprocket lines be level with the top of the head but "up" appears correct
so which is it / align with top of the head or the arrows on the back cover behind the sprocket
Most videos I watched and manuals I read all align with the top of the head and only 1 video I watched specifically spelled out the arrows on the cover
thanks
thanks
