ladagosta
03 Honda civic lx, coupe, auto, 1.7 156,000 miles (used to own a 01 civic lx 4 dr auto 1.8, I sold at 185,000 miles 22 months ago now i wonder why)
the other car the tranny went at 120,000, total failure, no warning, no indicator lights, cel, absolutely nothing; other than the cruise control indicated some issue whether it was a red flag to the tranny failure IDK...
well after 45,000 the tranny was indicating that it was going to fail so i researched and decided to sell it and i let the person know that the tranny had been replaced and was wearing down they didnt appear to care they wanted it because it was well maintained. i did history check on the 03 civic and found that the 03 04 and 05 civics seemed to have less "issues" with them specifically the transmissions..so i found this car 133,000 mi for a great price (i should have known that was a red flag right there) any way here are the symptoms as best as I can describe:
cold weather appears to cause the symptoms to become more prominent
start up there had always been a slight shake to the car only in idle, neutral and park when driving there is no shake smooth ride. i am leaning towards a mount going or gone bad somewhere i havent had the time or energy to investigate this to date but now i just may look at it more closely.
at every shift there is a hard shift, notable jump in rmps about 800 to 1000. no noises that i can hear but my hearing is going so idk.. i havent driven it that many miles since this symptom appeared but after the previous car i am now very concerned.
i have heard that it could be a tps issue that not always is it the clutch going bad in automatics or not necessarily eminent failure if you address the issue before mechanical issues become a problem. I heard that it could be a sensor or some other part that is easy to replace and not necessarily going to need a rebuild to fix the problem. I know my way around cars but not when it comes to transmission. the tech who did the trans fluid change test rode it and said it is going to fail. the question remains why is it going to fail? i have also heard that many honda owners never have any warning before the transmissions fail. now i want to know why? are the sensors bad and that is why they end up in failure? cause it seems to me when you are looking at 1 in 6 accords and civics end in failure seems that something is malfunctioning somewhere and most of them never have a warning i have read far too many complaints on honda over the past 5 years to just accept that this is "normal" most cars have a warning at least most other makes give a warning before failing.. so this gives me the HHHMMMM affect.
i had a transmission fluid change (not a flush; only because I do not want the dw1 fully circulating in the system until I know what it will do to the problem and cost of 100 + more for the flush and if it is a failure issue then why bother?) when i got the car the fluid was perfectly bright pink, now before the change it was very paled and there are slight signs of metal wear on the stick, so this is why i decided to rejuvenate the fluid a bit to see how it affects the symptoms.
I am ready and prepare to replace with a re-manufactured transmission, yet only if i absolutely need to if i can replace a 20.00 tps or a sensor for under 100 i will go that route first
so since the fluid change the symptoms have changed a bit instead of a hard shift and a notable jump in rmps. there is now a hesitation and a slight jump in rmps nothing like the way it was shifting but still not right so I want to know if anyone on here is familiar with transmission repair and / or diagnosis to give me an insight as to how i should approach this issue if the transmission is definately on its way out I know where i can get a rebuild for under a grand and have it installed for about 500 i will supply them with the dw1 to make certain it is genuine honda trans fluid as I do know also with the hondas if you use anything BUT genuine honda tranny fluid within moneths you are going to have to replace the transmission that is a known fact now with most honda owners. and so far it is the only transmission made where if you put anything else in it you are looking at replacing the costly item.. seems that in and of itself is not a very reputable thing to do to a very costly item to make it so if anyone puts any other product in your vehicle you will pay dearly for it.. never heard of any other company that has taken such a bold stance on their manufacturing methods. most often with most products sold you can buy non oem or universal replacement products and still have a working product . Sorry for the commentary but i am slightly annoyed and I used to stand behind Honda due to a long history of them being a very reliable car.. but now i will seriously begin to look the other way and what i am seeing with KIA they have come a long way with their product and I am considering either one of theirs or toyota for my next purchase.. especially if i end up replacing the transmission on this car within the next 6 months.. they arent what they used to be.. and i have learned the hard way they present too many concerns for a disabled person to be driving one and relying on it to get from point A to point B.. any insight and or suggestions to investigate on this tranny related issue please feel free to share i am presently open to all suggestions. thanks in advance. LAD
