Voodoo 13 is now available. They are a new company based out or AZ. Their products are made in-house in the USA with a limited lifetime warranty. The LCA's come with Energy Suspension bushings.
Voodoo 13 Rear Lower Control Arm
VooDoo13’s Rear Lower Control Arm are designed, engineered and tested on race tracks across the globe using feedback of top tier drivers and technical directors.
Advanced Bushings
Special engineered Energy Suspension polyurethane bushings allow optimal deflection rates and increased longevity over OE bushings.
Quality Throughout
Our aluminum flange bushing design allows maximum surface contact between the bushing and vehicle mounting locations while not allowing the bushing to prematurely wear.
Built to Last
Precision CNC machined from a block of 6061 aluminum. Unique “X” pattern is sure to tell the VooDoo13 arms apart from the competition. MIL-A-8625 Type III Hard Anodize is not your ordinary type of anodized finish; it is extremely durable and is damn near scratch resistant. You’ll have to take a chunk of metal out before you scratch this MIL-SPEC finish!
Limited Lifetime Warranty
Made in the USA
Shop at TunerSports
http://www.tunersports.com/voodoo-13-rear-lower-control-arm_mp1516.html
OR
Shop in the CC Store
http://www.clubcivic.com/store/voodoo-13-rear-lower-control-arm_mp1516.html
Voodoo 13 Rear Camber Arms
VooDoo13’s Rear Camber Arm are designed, engineered and tested on race tracks across the globe using feedback of top tier drivers and technical directors.
First Rate Performance
Specially engineered Energy Suspension polyurethane bushings allow optimal deflection rates and increased longevity over OE bushings.
Quality Throughout
Hardened 4140 chromoly steel rod ends are black zinc coated for protection against the elements
Built to Last
SAEJ429 Grade 8 zinc coated hardware is used to ensure they will withstand abuse
Made in the USA
Shop at TunerSports
http://www.tunersports.com/voodoo-13-rear-camber-arms_mp1515.html
OR
http://www.clubcivic.com/store/voodoo-13-rear-camber-arms_mp1515.html
Advanced Bushings
Quality Throughout
Built to Last
Made in the USA
Shop at TunerSports
OR
Quality Throughout
Built to Last
Made in the USA
Shop at TunerSports
OR
