ej8_st
So i have 00 civic ex with jdm 95 d15b vtec swap. I recently chipped my ecu and it threw code 22 so i was told to unplug my oil pressure switch by Phearable so that the code doesn't throw. Phearable said that the chipped ecu is supposed to jump the oil pressure switch itself. When I rev to 5500 rpm which is what i set vtec at, i hear nothing at all, even on my y8 i could hear a distinct engagement.
There are a couple things that I think is a possible reason for vtec failure:
My oil is a bit higher than normal level
I have a vacuum leak where my intake manifold meets my engine block causing unstable idle
i jumped the vtec solenoid and vtec pressure switch wire together.
vtec pressure switch is disconnected
ever since unplugging the switch i don't have any cel.
